stevegough
posted on 13/10/10 at 08:16 AM |
IVA compliant 350mm steering wheel?
What does the 'team' think? - maybe a bit teutonic for a se7en? But not bad at £40? Padded centre - might even satisfy the regs?
No good for me though - if I take the Sierra wheel off, I lose the steering lock which will mean adding an immobiliser or similar.
Anyway, might be to someone's taste on here?
Wheel
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
loggyboy
posted on 13/10/10 at 08:27 AM |
2 questions - does thje sierra wheel really link to the steering lock? I thought it was connected and activated within the column its self.
Even if that were so, are you not planning on having an electronic imobiliser installed anyway, I dont think id want to rely solely on a steering lock
to protect my car?
[Edited on 13/10/10 by loggyboy]
jack_t
posted on 13/10/10 at 08:33 AM |
the steering lock works by a spring loaded lever that latches onto the the inside of the the steering boss ( lots of teeth lining the inside of the
boss) which is part of the sierra wheel
i have a momo wheel on my car which has a boss that has the teeth on it so i still have the steering lock
Stott
posted on 13/10/10 at 08:34 AM |
The sierra steering lock shoots a square edge pin into grooves in the inside of the steering wheel on mine ('86 mk1 Sierra)
I've got a mountney boss which also has the grooves but less of them , so my steering lock still works with an aftermarket wheel, just a
thought, in case you did want to swap prior to IVA.
EDIT: too slow again lol, well at least now you know lots of different boss's will retain the lock
[Edited on 13/10/10 by Stott]
pekwah1
posted on 13/10/10 at 08:35 AM |
says in the ad that it's a 320mm not a 350
loggyboy
posted on 13/10/10 at 08:38 AM |
Everydays a school day - ford do like to do it cheap dont they! Either way, still wouldnt want to rely on a steering lock to be the only security on
my pride and joy.
Stott
posted on 13/10/10 at 08:46 AM |
Agreed, I rely on it never being finished, and thus never at risk as it don't come out' garage!
iscmatt
posted on 13/10/10 at 09:38 AM |
I wonder what the radius is on metal in the centre is, doesn't look particularly IVA friendly IMO...
posted on 13/10/10 at 09:51 AM |
quote: Originally posted by stevegough if I take the Sierra wheel off, I lose the steering lock which will mean adding an immobiliser or
similar.
My Mountney boss has the grooves in for the steering lock as did the one on my old car.
lewis
posted on 13/10/10 at 03:36 PM |
I have fhe steering lock still functioning with a boss and omp wheel so not all sierra columns are the same?
