Author: Subject: Fan fitting Kit?
Benzo
posted on 23/8/11 at 09:54 PM Reply With Quote
Fan fitting Kit?
Hi Guys,
After a front end shunt i have damaged my Nose/ Rad/ Fan...
I have now everything squared up again but the Fan, the plastic clip in mounts have broken and now im left with a Fan in perfect working order but no way of mounting it to the rad again, i had thought about fitting the fan using some pieces of alloy angle but not fussed on metal mountings against the Rad fins..
The Fan is made by 'Jaguar Precision' googled it and its a company in Taiwan who only list the Fan itself.
Here are some pics..
Does anyone know if you can buy these clip in mounts? or should i just buy a new fan? seems like a waste to ditch it!
I have found where to get new pins on rally design to put through the Rad..
http://www.rallydesign.co.uk/product_info.php?cPath=531_2061_2063&products_id=14662
Any help would be great...
But no angled plastic clips
eddie99
posted on 23/8/11 at 10:04 PM Reply With Quote
Just cable tie it through the radiator??? Not as perfect a solution but it works
Benzo
I had no idea a Fan was so cheap!
Do i just go and buy one like this?
Electric Radiator Cooling Fan 10' Push/Pull Universal | eBay
£18 +£5 Del.
Benzo
posted on 23/8/11 at 10:07 PM Reply With Quote
Yeah i suppose so, not as tidy a solution either, but i suppose it will solve the problem!
Johneturbo
posted on 23/8/11 at 10:19 PM Reply With Quote
Araldite the tangs back on
Benzo
posted on 23/8/11 at 10:32 PM Reply With Quote
2 of the angled clips have also gone walkies.. so araldite is out the window...
jabbahutt
posted on 24/8/11 at 08:52 AM Reply With Quote
could you not use the radiator fan mounting kits sold by the likes of CBS? round tir wrap type affairs that go through the radiator cores and are held in place by small square bits of plastic.
hold the radiator very securely and bit neater than tie wraps if that sort of thing bothers you
big-vee-twin
posted on 24/8/11 at 08:55 AM Reply With Quote
I have used one of those fans after receiving recommendation on here to use it
http://www.triangleltd.com
Benzo
posted on 24/8/11 at 09:56 AM Reply With Quote
http://www.cbsonline.co.uk/mobile/product/Fan_Mount_Kit_With_Assorted_Feet_FNMNT2
Hadn't heard of CBS before but that sounds like exactly what I'm
After!
lsdweb
posted on 24/8/11 at 11:04 AM Reply With Quote
Radiator tie through the holes in the fan body next to where the mounting point is.
lsdweb
posted on 24/8/11 at 11:07 AM Reply With Quote
hole
hole
