Author: Subject: Which type of sender on a type 9 box
omega 24 v6
posted on 13/12/11 at 07:53 AM Reply With Quote
Can anyone advise on which type of electronic sender is on the granada style type 9 box for the speedo pick up.
Is it an inductive or a hall effect.
I need info to connect to a vdo gauge but as of yet have seen neither the gauge or the gearbox.
Thanks in advance folks
karlak
posted on 13/12/11 at 08:15 AM Reply With Quote
I can't help with how it works, but I discovered that I have one on my gearbox when it was removed.
At least I believe this is the electronic sender ? My car was built with the standard cable speeedo though, this was/is not connected.
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
Tiger Super Six
posted on 13/12/11 at 09:21 AM Reply With Quote
I think it is a hall effect - I had a gearbox built by BGH and asked them to put one in it. I then connected it to an ETB dial which usually works on hall effect (two magnets on the prop and a sensor).
Mark
Tiger Avon
omega 24 v6
posted on 13/12/11 at 12:20 PM Reply With Quote
Information update is that it is 2 wire sensor. Anyone?? It has to be used there is no option on magnets etc.
ETA I found this so maybe a 2 wire inductive sensor??
http://www.egauges.com/pdf/vdo/0-515-012-051.pdf
[Edited on 13/12/11 by omega 24 v6]
davidimurray
posted on 13/12/11 at 12:36 PM Reply With Quote
Probably not much but when i bought my Koso dash from Saturn Sportscars they supplied a little adaptor that fits an electronic sensor into the cable location.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
Tiger Super Six
posted on 13/12/11 at 12:55 PM Reply With Quote
I have just had a look back through my posts on the Tiger forum from 2006 when I did this and I mentioned that it is cog driven (so I guess not hall effect) but it could still be used with the ETB hall effect speedo as I have to recalibrate it.
The only thing was that the speedo had 3 wires (yellow, brown from memory but can't remember the other) and the speedo only had 2.
I have tried to look for the wiring information for the wires I used but I can't find it by doing searches on the forum, but it did work after I recalibrated it.
HTH
PS - I am pretty sure that BGH told me what each of the wires did, so might be worth a call to them?
PPS - just found the thread which gives what each wire is http://www.locostbuilders.co.uk/viewthread.php?tid=52742 and wiring colours http://www.locostbuilders.co.uk/viewthread.php?tid=48096
[Edited on 13/12/11 by Tiger Super Six]
Mark
Tiger Avon
