Author: Subject: Savage Switches - Remove / install
Acc8braman
posted on 28/8/13 at 04:52 PM Reply With Quote
Sorry for a numpty question but I need to rewire my rear fog light to meet current IVA regs.
These means removing the Savage switch, so on and so forth.
This is where I stumble over, not having instructions, for the life of me, I cannot figure out how the damn thing is removed!!!
Please can some one help, there must a magical hole or something or other I cannot see
loggyboy
posted on 28/8/13 at 04:56 PM Reply With Quote
There is a plastic thread on the switch with a metal bush, its behind the dash, unscrew it and it will slip out.
[Edited on 28-8-13 by loggyboy]
Mistral Motorsport
Acc8braman
posted on 28/8/13 at 04:58 PM Reply With Quote
I un did that but nothing?!
Does it need the Force?!
carlknight1982
posted on 28/8/13 at 04:59 PM Reply With Quote
shouldnt do unless you have glued it in.
Logic will get you from a A to B
Imagination will take you everywhere.
carlknight1982
posted on 28/8/13 at 05:00 PM Reply With Quote
Stolen from Bens photos
hope this helps
Savage switch wiring
cloudy
posted on 28/8/13 at 05:14 PM Reply With Quote
The square switch housing might need to come off first - it's on a barb
James
www.warnercars.com
Acc8braman
posted on 28/8/13 at 05:31 PM Reply With Quote
James
James, I see, so I pull on that first then can remove the thread?
cloudy
posted on 28/8/13 at 06:13 PM Reply With Quote
Yep, leaves just the barrel AFAIK which will then fit back through the mount hole
www.warnercars.com
Acc8braman
posted on 28/8/13 at 06:26 PM Reply With Quote
Hmm, no luck just pulling on it, am I being a wimp as I don't want to break it
omega 24 v6
posted on 28/8/13 at 06:52 PM Reply With Quote
there is a small leg you need to push in while you pull.
ETA is anone else getting a malware blocked on this page from avast??
[Edited on 28/8/13 by omega 24 v6]
bi22le
posted on 28/8/13 at 07:09 PM Reply With Quote
Again, one the square bit at the back where the terminals are there shpuld be a barb. If ypu cant find it or it dont just slide off then its been glued on. Happened to two of mine. I had to replace them. They are not xheap.
Please read my ring story:
renetom
posted on 29/8/13 at 07:44 AM Reply With Quote
Hi
This is our switch & wiring
As others have said the square switch section need to come off
first & it is on a barb,
there is a small leg you need to push in whilst you pull the 2 bits appart.
but before you do this you need to disconnect the 2 wires to A&B
terminals, as these are attached to the top removable part of
the switch ( for the switch to light up)
Then just unscrew the ring which clamps it to the dash.
I can see no earthly reason why anyone would glue them in.
Having said all this we did all our dash wiring on the bench which made life a lot easier & used a large connector to attach it to the car,these switches are pretty & fashionable but are poorly designed & not brilliant quality, although none of ours have failed yet.
Switch without the square section
The bit you push to release the barb
good luck
[Edited on 29/8/13 by renetom]
