Author: Subject: bedford rascal alternator
theconrodkid
posted on 18/3/03 at 05:31 PM Reply With Quote
anyone know if the rascal/suzuki jeep(sj410)/carry are the same sort of size as the daihatsu item?
who cares who wins
pass the pork pies
bob
posted on 27/8/03 at 07:04 PM Reply With Quote
yep same size mate
Which term goes where as they are both the same size,i know one goes to charge light and one to battery via starter.
spose its a case of suck it and see
[Edited on 27/8/03 by bob]
Dusty
posted on 28/8/03 at 11:17 AM Reply With Quote
On the Rascal alternator I have, there is an insulated M8 stud and a 13mm nut for take off to the battery (via starter if you want). There are two 6mm spade terminals in a T shape in a recess. Top one IG, and upright marked L. I use L for ignition light.
[Edited on 29/8/03 by Dusty]
bob
posted on 28/8/03 at 07:27 PM Reply With Quote
DUSTY
I. O. U. 1 beer
thanks a lot
bob
posted on 29/8/03 at 09:29 PM Reply With Quote
Hold up!!
doesnt the alt have to go to earth somewhere ?.
posted on 29/8/03 at 10:19 PM Reply With Quote
unless it earths thru the block! i dunno...
Dusty
posted on 30/8/03 at 03:16 PM Reply With Quote
The insulated M8 terminal is the positive to battery pos. Depending on manufacturer usualy labeled A, BAT, B, B+, 51, or 30.
Ignition lamp usualy runs off a terminal labeled D, L, WL, I 61.
Most alternators earth through the casing into the block but if there is an earth wire it would be labeled B-, D-, E, G, GRD, M-, 31 or 31- according to my crib sheet.
[Edited on 30/8/03 by Dusty]
bob
posted on 30/8/03 at 07:28 PM Reply With Quote
cheers Dusty
