Author: Subject: Wiring connector needed, pic attached
se7ensport
posted on 22/7/06 at 08:17 AM Reply With Quote
I can't find anywhere that sells these little buggers
wiring connector
wiring connector
They are 20mm long 3mm wide.
As fas as I can tell pretty much all modern cars use these as standard within the wiring loom, but none of my local automotive (boy-racer) shops sell them.
Alex
MikeR
posted on 22/7/06 at 08:36 AM Reply With Quote
premier wiring will sell them to you (and the plastic blocks they go in)
se7ensport
posted on 22/7/06 at 08:47 AM Reply With Quote
Thanks Mike, spot on!
Krismc
posted on 22/7/06 at 11:51 AM Reply With Quote
polevolt sell them, as do vehicle wiring products
ned
posted on 22/7/06 at 04:34 PM Reply With Quote
vehicle wiring products will definately have something to fit..
beware, I've got yellow skin
posted on 24/7/06 at 01:32 PM Reply With Quote
I think I may have some of these, bought from VWP - is you need a couple, then I put some in an envelope & send - will save you on the extortianate P/P VWP charge
