Author: Subject: Lighting
Davey D
posted on 3/4/08 at 11:20 AM Reply With Quote
Lighting
Im looking around at all the usual places to pick some headlights, and Tail lights for the VortX.
I like the Headlights at the top of this page.. The 110mm ones...are they SVA-ok?
http://www.premierwiring.co.uk/index.php?module=Website&action=Text&content=1133393686882-8823&parentContent=1133392767901-3830
and has anyone else used the PEREI "free form" lens lamps which are a bit further down the page? if so do you have any pictures of them fitted?
posted on 3/4/08 at 11:38 AM Reply With Quote
With regard to the headlights, the 110mm dia headlights will not/should not pass SVA without some major work on the lenses. They are made for motorcycles and have the wrong beam pattern. They also have the incorrect marking on the lens.
Having said that, there are people who claim to have passed SVA with these headlights. Your decision I guess but personally I'd fit some proper ones.
Phil
Davey D
posted on 3/4/08 at 11:56 AM Reply With Quote
In that case, would the:
SATURNUS 5¾" black headlamp £55.00 pair
a bit lower down be ok?
posted on 3/4/08 at 12:14 PM Reply With Quote
Got mine from MNR, can you not?
Davey D
posted on 3/4/08 at 12:32 PM Reply With Quote
How much were yours from MNR?
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 3/4/08 at 12:33 PM Reply With Quote
I passed SVA with the 110mm ones. i did a small modification which involved turning the lens in its housing about 4/5 degrees so that the beam was directed to the curb. Only required the loosening of a screw to loosen the casing and then turn the lens.
Of course this was my experience and others may think/had experience that does not agree.
PAUL FISHER
posted on 3/4/08 at 01:05 PM Reply With Quote
These are the perei,free form lamps fitted,supplied by premier wiring
Davey D
posted on 3/4/08 at 01:15 PM Reply With Quote
Excellent.. thanks for that
Ill be getting some of those then. Do they come with the spacer rings, and bulbholder/wiring?
Also i see you have a different spacer on the foglight. did it come with that one, or did you buy it separate?
PAUL FISHER
posted on 3/4/08 at 01:37 PM Reply With Quote
oop's,sorry,mine are not the free form,mine are the led type,of the same lamp,the ones just below of there webb page,but they look the same when fitted anyway,they just fit flush with the wing,and they just have the wiring tails out of the rear of the unit,the fog lamp housing I bought from car builder solutions.
graememk
posted on 3/4/08 at 02:49 PM Reply With Quote
how about a set of jcb lights ?
graememksvafront
graememksvafront
posted on 3/4/08 at 03:32 PM Reply With Quote
if I remember rightly a full set front and back for £180? Mind the headlamps were used.....
Steve @ sVc
posted on 15/4/08 at 03:01 PM Reply With Quote
There are many companies selling these 95mm lights. Please make sure they have the right angled connectors at the rear - otherwise they will probably foul the rear wheel.
Also ask the supplier if the wiring connectors are included in the price.
Best wishes
steve @ sVc
