Author: Subject: Supressors
l0c0st
posted on 12/4/08 at 04:09 PM Reply With Quote
Supressors
Will the suppressor from the pinto alternator work with a micra alternator? Pic attached. The micra one (top) has broken so was wondering if i could use the old rectangular pinto one. The numbers on the side don't mean a lot to me!
pinto and micra suppressors
Cheers Dom
nitram38
posted on 12/4/08 at 04:12 PM Reply With Quote
Unless you are running a radio in the car, throw them away!
They are basically a capacitor which helps reduce radio waves, but can cause problems if the break down or short out.
l0c0st
posted on 12/4/08 at 04:32 PM Reply With Quote
Excellent, Thank you Nitram.
graememk
posted on 12/4/08 at 05:21 PM Reply With Quote
with out it my megasquirt wont work correctly
r1_pete
posted on 12/4/08 at 06:41 PM Reply With Quote
The 2.2 is the value of the capacitor, 2.2 micro farads, use away.....
posted on 12/4/08 at 08:20 PM Reply With Quote
2.2 is the capacitance value - 2.2 µF ( ooh look at me with my fancy greek symbols )
the other numbers would appear to be working voltage, 100 and 150 V.
as mitram says, you don't need it unless you have fancy electronic gubbins
