Author: Subject: Perei rear lights
Mark G
posted on 13/6/08 at 08:52 PM Reply With Quote
Perei rear lights
Hi all,
I have a set of perei rear lights. I have the indicators and side/brake lights. They are 2 pin and 3 pin connectors. I don't have any wiring connectors to fit the plugs on the lights.
Has anyone found or know of anywhere I may be able to buy the connectors for these lights.
Lights are the same as below.
Thanks in advance.
Mark.
[Edited on 13/6/08 by Mark G]
jos
posted on 13/6/08 at 08:57 PM Reply With Quote
MAC#1
Pdlewis
sorry cant help with the plug but where did you get the lights?
Mark G
posted on 13/6/08 at 09:08 PM Reply With Quote
I bought them used from a chap on here. I imagine that Mac1 sell them.
clairetoo
posted on 13/6/08 at 09:12 PM Reply With Quote
I got some off fleabay not long ago .
Its cuz I is blond , innit
Claire xx
Will weld for food......
irvined
posted on 13/6/08 at 10:55 PM Reply With Quote
Having just had a look for the same thing - they are mini timer connectors but with an extra detent - apparently you can get a standard mini timer connector and file off the detend from the lights and it will fit, or you can pay a bit more for the correct one.
Premier wiring can supply them (But are currently out of stock.)
http://irvined.blogspot.com
mistergrumpy
posted on 14/6/08 at 11:23 AM Reply With Quote
Are you after the plastic 90 degree wiring plug/bulb holder. If so then car builder solutions have them here. They are listed under the light at 2.99 each plus the p&p. If its the actual little steel tabs that crimp onto the wire and insert into the plug then I've seen them at Maplins.
Steve @ sVc
posted on 17/6/08 at 12:16 PM Reply With Quote
90 bulb-holder conncectors.
You can get them from us @ sVc - we supply them included with the lights we supply.
Regards
Steve @ sVc
