Author: Subject: tin top help please
AndyW
posted on 5/6/10 at 04:59 PM Reply With Quote
tin top help please
Hi All,
I hope some one can help me, the wife's renault megan 04 has a problem. N/S electric window has gone down on its own, I striped door card and found motor has water in it, took to bits, cleaned dryed and put back, window went up. Just been outside and the n/s window is down again and now none of the windows or electric roof work! checked all fuses and all seem ok.
Any help appreciated.......
Ninehigh
posted on 5/6/10 at 07:27 PM Reply With Quote
I suppose for now get it up and stick it in position (disconnect motor).
Maybe there's a relay been blown?
l0rd
posted on 5/6/10 at 08:41 PM Reply With Quote
http://www.renaultforums.co.uk/showthread.php?t=81618&highlight=megane+windows
try there.
common fault
big-vee-twin
posted on 5/6/10 at 10:57 PM Reply With Quote
Think they are controlled by the ECU mine went daft when I removed it to check a fault - need to reset.
Disconnect and reconnect battery and try them again - although this can cause fun with your radio.
http://www.triangleltd.com
AndyW
posted on 6/6/10 at 01:35 PM Reply With Quote
Problem solved, burnt out winow motor near side front, fried multi plug and fused together 2 wires that knocked out all other windows and roof. Seperated wires and insulated them and everything works fine. Had a lucky escape as burning motor had even scorched the glass and was mins away from fire. Luckily system is dead without ignition and swmbo has been useing my car.
