Author: Subject: Mad Camaro Turbo - EEEEEK
T66
posted on 5/6/10 at 05:18 PM Reply With Quote
I thought the front end picture of the twin turbos was a photoshop fake, its NOT !
http://v8tvshow.com/forum/index.php?topic=254.msg990
Guihanos
posted on 5/6/10 at 05:35 PM Reply With Quote
It seems to be over for the car now..
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 5/6/10 at 06:26 PM Reply With Quote
Your avatar = good times
Ninehigh
posted on 5/6/10 at 07:35 PM Reply With Quote
F**k me they're some big turbos
mangogrooveworkshop
posted on 5/6/10 at 07:56 PM Reply With Quote
cheeeewizzz
"Well, after 80 hours of work, we finally got it on the dyno and running.....only pulled it a little (between 4000-7500) just to warm it up to we could lash the valves and check everything
The Fast Times built, Sonny headed, 548 cubic inches, with twin 88's with ONLY 2 pounds of boost( waste gates wide open), it made 1009 horsepower at 7500 and it still hadn't gotten to peak torque, so it looks like the motor will go to 9000-9500 or so and with some boost it should make a little more...lol
the goal is a reliable 2800 horsepower at only 25lbs of boost.
