Author: Subject: bike clutch problem?
thunderace
posted on 14/9/10 at 02:42 PM Reply With Quote
see the video i have done to show my problem ,i hope someone can help me work out the problem.
http://www.youtube.com/watch?v=MKTkdT4PheI
MakeEverything
posted on 14/9/10 at 02:47 PM Reply With Quote
Were the clutch plates the same thickness and the same number of?
sounds like its dragging, but i wouldnt grind any more off of the bike!!!
Kindest Regards,
Richard.
MakeEverything
posted on 14/9/10 at 02:50 PM Reply With Quote
Also, are you sure you have;
Put the plates in the right way round?
put the plain plates in between each plate?
I had the same problem, and somehow had put two plain plates together, which meant two friction plates together. It dragged and slipped like a bastard.
ETA: the Basket could also be worn...
[Edited on 14-9-10 by MakeEverything]
Kindest Regards,
Richard.
MakeEverything
posted on 14/9/10 at 02:52 PM Reply With Quote
Just watched it again, and the beginning is like watching the Krankies!
Kindest Regards,
Richard.
posted on 14/9/10 at 03:00 PM Reply With Quote
Did you soak the plates in oil overnight before you fitted them and did you buy a genuine cable ? Usually you can set the cable with the adjustment at the clutch end then use the handlebar adjustment after that.
Andy B
posted on 14/9/10 at 03:31 PM Reply With Quote
I would also check the condition of the clutch pawl shaft, fitted in the cover, if the end that is in connection with the centre pawl is worn it will turn a long way before anything happens. This will be further exagerated by the heavy duty springs. I think it is difficult to get neutral, not because its slipping but because it is not fully diengaged and therefore under load.
regards
adithorp
posted on 14/9/10 at 03:34 PM Reply With Quote
Did you get the release lever engaged in the right place. It looks on there like the lever is pulled too far around. Shouldn't the starting point be further back so the pull starts before 90' and ends after. That'd give the most throw on the lever. If it's pull starts after 90' (between lever and cable) the angle turned will be reduced.
http://jpsc.org.uk/forum/
thunderace
posted on 14/9/10 at 05:16 PM Reply With Quote
regards
i will try the clutch pawl shaft as i havent looked at that
yes its under load so wont go into gear thanks for the advice .
thunderace
posted on 14/9/10 at 05:18 PM Reply With Quote
cheaky bugger lol
RichardK
posted on 14/9/10 at 07:28 PM Reply With Quote
Is the clutch on the opposite side to the crancase lever ie could it have problem with the clutch push rod, ie too short??
Just had a check and cant see a push rod but maybe worth having a look at the clutch section here to see if anything is missing.
Rich
[Edited on 14/9/10 by RichardK]
Gallery updated 11/01/2011
thunderace
posted on 14/9/10 at 09:21 PM Reply With Quote
thanks its a cmx450c i have the full manual for the bike and had a 80s honda machanic have a quick look today so im going to remove the case and have a look i just replaced the gasket it cost me £45 from the usa inc tax and shiping.
thunderace
posted on 16/9/10 at 06:08 PM Reply With Quote
regards
SORTED AT LAST IT WAS THE PAW THANKS ANDY
THE GUY MUST HAVE LOST THE ORIGINAL ONE AND MADE ONE TO FIT AND IT WAS 6MM TOO SMALL SO DIDNT PUSH THE CLUTCH BACK TO MAKE IT WORK 100% ,A HARD ONE TO FIND BUT GOT THERE IN THE END.
THANKS FOR ALL YOUR HELP AND ADVICE GUYS.
mistergrumpy
posted on 16/9/10 at 09:35 PM Reply With Quote
I carry 5 spares of these in the car for this reason! I kid you not!
