Poll: How much does my car worth? [View Results]
less than 100
100 - 300
300 - 500
500 - 600
600 - 700
700 and over (Be realistic it won't happen)
Author: Subject: How much does my car worth?
l0rd
posted on 12/11/10 at 05:51 PM Reply With Quote
I haven't made up my mind yet but I might be selling my car as i will move back to Greece.
I checked ebay and omg i am going to pull my hair out. I am going to get absolutely peanuts.
Laguna MK1 Ph2 2000 model 1.8 16v petrol.
113K miles but will get to 115 by then probably. There is some service history with it. Mostly the one that i kept from Renault Specialist.
I have spend about 1200 quid on servicing since i got it about 20 months ago and has been driven for 35K miles. All the major work has been done during servicing.
Fully synthetic Oil every 15K miles
Newish front discs and pads and sliders cleaned and greased
Rear brakes have been dismantled and cleaned
New midle section exhaust
Timing Belt kit (powergrip) 20-25K miles ago
NGK iridium Spark plugs ( i think or Denso iridium sorry i forgot)
K&N panel air filter
New tires 3000 miles ago
New steering arms
Rear left wheel bearing 8000 miles ago
New lower dogmount
Needs doing in the future
Waterpump as precaution
Auxiliary belts and tensioners
Service Oil/Oil filter/Sparkplugs
Rear Backbox
There are some dings around the car that happened before my ownership. The car drives without a fault and the only electrical problem occured was the heater resistor pack that was fixed by installing a new thermal fuse.
l0rd
posted on 12/11/10 at 06:08 PM Reply With Quote
Ohh by the way, i am the only one that clicked the 700 and over
posted on 12/11/10 at 06:20 PM Reply With Quote
Thats ok, up until now I am the only one that clicked less than £100, so that kinda balances things out.....
Phil
l0rd
posted on 12/11/10 at 06:23 PM Reply With Quote
Phil
My alloys and tyres are about 200 minimum as they have
4 Continental Premium contact SSR (Run Flats) at £90 each.
posted on 12/11/10 at 06:29 PM Reply With Quote
So why do you have 'less than 100' in your poll?
Phil
l0rd
posted on 12/11/10 at 06:34 PM Reply With Quote
Phil
To make sure how much it is worth if i scrap it
fesycresy
posted on 12/11/10 at 06:37 PM Reply With Quote
Why fit £90 boots on an old car?
Have you tried your local Free ads paper?
prawnabie
posted on 12/11/10 at 06:48 PM Reply With Quote
Ive seen a 53 plate 1.9 dci and a 1.8 16v both go for 450 today at auction - both had around 80k on the clock
l0rd
cause i used to drive 120 miles a day on motorway. If i got a flat tire, the last thing on my mind would be to pul over and change it.
l0rd
posted on 12/11/10 at 06:49 PM Reply With Quote
Yes but the dci is a bomb ready to explode.
prawnabie
posted on 12/11/10 at 06:51 PM Reply With Quote
How did you work that out?
prawnabie
prawnabie
l0rd
posted on 12/11/10 at 07:32 PM Reply With Quote
Due to the common 1.9 diesel engine failures.
interestedparty
posted on 12/11/10 at 07:47 PM Reply With Quote
You need to say how much tax and mot is on the car, that info is vital
l0rd
posted on 12/11/10 at 09:14 PM Reply With Quote
Indeed
Taxed till end April
Moted till Mid-end Feb
Ninehigh
posted on 13/11/10 at 02:34 AM Reply With Quote
Overall what condition is it in? Should fetch £700 easily if it's pretty mint
907
posted on 13/11/10 at 08:04 AM Reply With Quote
That's what I would term a short MOT.
If the car is mechanically sound then put a years ticket on it.
Spend 50 quid and it will add a couple of hundred (or more) to the value, plus loads more people will
come to view. (or bid if on eBay)
A good clean works wonders as well.
Just my opinion.
Paul G
l0rd
posted on 13/11/10 at 09:11 AM Reply With Quote
The car is spot on mechanically.
It is clean. Waxed every 3 months. There is a hairline crack about 1.5cm long that just started rusting underneath the color but it is not very obvious and this is the only rusty spot in the car.
It is not mint but it is not bad either.Normal wear and tear. That is the problem.
