Author: Subject: IVA Date Confirmed :)
Acc8braman
posted on 11/11/13 at 12:16 PM Reply With Quote
Well, had the phone call this morning, IVA is now booked in for the 21.11.13
Bright and early start
Daverog
posted on 11/11/13 at 12:39 PM Reply With Quote
Good luck with the test, where are you taking it??
Acc8braman
posted on 11/11/13 at 12:47 PM Reply With Quote
Thanks Dave,
Going to Derby, just trying to find the address now and the nearest petrol station.
Two jobs left to do, attached the chassis plate and fix the side repeaters so they can be seen from the rear.
Daverog
posted on 11/11/13 at 02:09 PM Reply With Quote
I fell foul of the side repeaters, mine were on the edge of the rear wing, but more than 2.6m from car front!! Didn't think the car was as long as it is!!!
Acc8braman
posted on 11/11/13 at 02:16 PM Reply With Quote
blimey, didn't realise there was a limit. Mine will be on the wing mirrors, just need to figure out how to do it, but reasonable straight forward to do.
40inches
posted on 11/11/13 at 02:20 PM Reply With Quote
I would recommend Nottingham, they will do everything they can to get you a pass.
Acc8braman
posted on 11/11/13 at 02:22 PM Reply With Quote
What about Derby, had it recommended?
Daverog
posted on 11/11/13 at 02:54 PM Reply With Quote
Took mine to Nottingham, although Derby was nearer. Derby rumoured to be staffed by IVA Gestapo!!
DavidM
posted on 11/11/13 at 10:21 PM Reply With Quote
I see you are quite local. You'd be warmly welcomed to the Northants group meeting if you fancied coming along.
http://www.locostbuilders.co.uk/viewthread.php?tid=186568
Proportion is Everything
Acc8braman
posted on 11/11/13 at 10:24 PM Reply With Quote
Originally posted by DavidM
Deffo will be up for that, have a friend in desborough who is also in the final rebuild stage of his car so he will love to come along also.
Hopefully on the road before Xmas
DavidM
posted on 11/11/13 at 10:44 PM Reply With Quote
We look forward to meeting you both. Good luck with the IVA.
Acc8braman
posted on 20/11/13 at 08:08 PM Reply With Quote
Had a frantic day today sorting out fogs, sorted with help from A friend.
Got car up to temp and sprang a leak on one of the hoses, tightened it up and the clamp busts!!! So found another one and it stopped it
Then the fans didn't kick in !!! Took side panels off to see if loose wire, nope. Checked the fuse at the batt, blown, damn 1hr wasted.
All sorted now, batt on trickle charge, jump start battery on charge.
All paper work ready, tools ready.
Glass of wine and early night. For the 4th night running, I will be wide awake at 2am
Looking forwards to it strangely
DavidM
posted on 20/11/13 at 09:29 PM Reply With Quote
Good luck at the IVA tomorrow, I hope it all goes well.
Acc8braman
posted on 21/11/13 at 07:21 PM Reply With Quote
Hi All,
Well, it failed, but I am not unhappy.
Had a great experience at Derby, Roy was the tester and what a great guy he is
I will do a proper write up over the next couple of days to help others of what things I had to do / change / pointers, but here are my fail points :-
1) Noise - recorded 102.8 - decibel killers?
2) Park Brake - no reserve travel ( passed efficiency though )
3) Brake performance - should be split 60/40 to the front - mine totally reserved - head scratching time ???
4) Front indicators - we all know this one - simple, remove them and put LEDS on the mirrors
5) Headlamps - lamps putting up and right - should be left!! wrong lenses which I will need to source.
And thats it
Did fail on emissions - double permissible but allowed me to phone a friend, he even rang his Friend who told me how to adjust the carb correctly
Roy tried his best to help me get the car through but the above was not rectifiable on the day.
Great day out, even drove home, loved it
Strangely happy and disappointed at the same time
b3ngy
posted on 21/11/13 at 08:34 PM Reply With Quote
Well done....doesn't look too bad, nothing major to sort there.
Can I just ask how long it took from posting application to receiving IVA date??
Acc8braman
posted on 21/11/13 at 08:45 PM Reply With Quote
Thanks,
Approx 3 weeks from posting.
Acc8braman
posted on 27/11/13 at 06:13 PM Reply With Quote
After options on proportional valves and IVA- want to use one to reduce the pressure to the rear brakes.
Will this be ok?
Andy S
posted on 27/11/13 at 06:25 PM Reply With Quote
If its tandem cylinder do you have the circuits connected correctly? P to the front S to the rear
