Author: Subject: RX8 Haynes Roadster coming soon....
JonnyH
posted on 15/10/14 at 07:36 PM Reply With Quote
Hey all
Thought it best to introduce myself seeing as i'm new n'all and see what you all think of my plans.
As the title would suggest, planning to build a Haynes Roadster using an RX8 as a donor.
So far it's all only in the planning stages, move house at the end of the month and at very long last i will have a garage. Would be a shame to to put it to good use!
The intention is to use the engine and gearbox, diff, hubs, breaks, column and just about anything else i can salvage.
As for the ECU, that can go in the bin as it's far to complex and will use a Megasquirt. Was thinking about scraping the intake and using ITBs but after further thought decided will be easier and more fun to use some of the stock intake and bolt on a supercharger. All things going to plan should be pushing 350bhp+
I'm quite lucky being a CNC machinist, i have the facilities to make custom parts with ease. And soon to be working next door to the companies composites facility there is a good chance carbon fibre will feature heavily (or is that lightly )
So come on, feel free to cast opinions etc. I figure there going to be a bit of hate on the wankel...
Jonny
Nickp
posted on 15/10/14 at 07:45 PM Reply With Quote
Sounds excellent, I do love a good wankel!!
I used to have a rotten old RX7 TurboII that I ran in the PPC £999 challenge. Great car, especially the engine, just rotten as a pear
Kinda wished I'd kept it as a donor
Does the Megasquirt work ok with the wankel then? Do they still have twin spark plugs per rotor as the turbos used to, with delayed firing?
JonnyH
posted on 15/10/14 at 08:02 PM Reply With Quote
I did consider an RX7 as a donor for a twin turbo fun, but they rare as rocking horse s**t and would be a shame to dismantle one unnecessarily.
They indeed do still have twin plugs with a delay. But after talks with Megasqurt, thanks to one of the creators owning an RX7 this is something they can accommodate
The oil metering pump is going to be hassle as it's controlled by the ECU depending on engine load and the Megasquirt can't doing anything with it.
Pre-mix is an easy solution, but ideally i'd like to run both.
PorkChop
posted on 15/10/14 at 08:59 PM Reply With Quote
There's at least 1 car Stateside that has an RX-8 engine and box using IIRC the standard ECU and clocks. There is also a guy on MX5Nutz who has a Renesis in his mark 1 MX5. And a third on here has one in a Westie.
I looked at putting a Renesis in my build along with mark 1 MX5 running gear. The challenges I saw were...
  • bigger bellhousing, with possible fun and games getting the starter motor to fit
  • the exhaust manifold wants to be in the same place as the steering column
  • you'll be more or less on your own designing the wishbones to suit the RX-8 uprights
  • it might need a very quiet exhaust - rotaries tend to be louder than piston engines
  • trying to retain the OMP could be very expensive to do - I think Adaptronic in Australia do an ECU that can handle it. That's the ECU the guy on Nutz used
  • if you get an engine with issues (which is what I was looking at doing), the seals and gaskets etc would probably need to come from the States and I would be sitting down if you need to find out how much complete rebuild kits and rotor housings cost
  • it's not THAT much lighter than a mark 1 MX5 engine and box
  • consumables are not cheap; coil packs can fail, OEM replacements are about 250 quid, spark plugs can be over 100 quid.
However, the Renesis is a very smooth engine, either a 192 or 231 would be plenty in a Roadster/Locost and lots of fun.
Good luck with it, whatever you decide to do
[Edited on 15/10/14 by PorkChop]
JonnyH
posted on 15/10/14 at 09:16 PM Reply With Quote
Thanks, this that could come in quite handy to know!
I believe there is also a guy in the states who has one in a Roadster with the auto box (yeah i dunno why you'd do that either) which is quite a bit bigger than the manual. Had to do a few modifications but it fit.
I'm planning to use the 192 engine, the intake is much simpler without the SSV. Getting that to work isn't worth the head ache!
It's also a 5 speed which saves a bit of weight. In a car so light really don't think the close ratios of the 6 speed are worth bothering with.
As for the starter and manifold, yeah i'll have some 'fun' squeezing them in no doubt.
You can pick up an RX8 with under 50k for less than 2 grand, least then i know there is a good chance it's all in reasonable condition. Once it's up and running i'm going to rebuild the engine anyway, full kit from the states is about 1k without housings. They are silly money!
The OMP is going to be a pain. There are some groups that have worked on putting the engines into planes and developed a unit just for controlling the OMP but finding anything out about them is proving tricky.
It cant be that hard, can it?
In a very basic form all you'd need is something that can take a reading from the throttle position sensor and drive a stepper motor accordingly.....
PorkChop
posted on 15/10/14 at 09:50 PM Reply With Quote
That's the guy I was thinking of in the States.
From reading the build thread of the Renesis'd MX5, I felt that I would try to either run without the OMP and use a premix, or use the standard ECU/OMP in it's entirety. That's just me personally. Plus the cost of pretty much all the parts put me well off too...
In the end I've decided to go for a lightly tuned early MX5 1600, so I stopped thinking about rotaries then, so not sure if either option would have worked!
JonnyH
posted on 15/10/14 at 10:05 PM Reply With Quote
Pre mix is a pretty good substitute for the OMP if you use a good quality oil.
But in an ideal world i'd like to use both, with the extra power from the supercharger want to give it the best i can.
Another possibility could be modifying the mechanical OMP from an RX7, but I've no idea if that's actually possible or practical.
I really cant be dealing with the stock ECU, from what I've seen on other standalone conversions getting it out out of limp when you unplug all the bits you don't want is a lot of hassle!
Dualist
posted on 16/10/14 at 08:36 AM Reply With Quote
I started mine a bit ago but life just go in the way a bit, good luck with the build
http://www.haynes.co.uk/forums/showthread.php?t=8521
Rotary build coming soon...
Originally posted by RichardK
I recently discovered that pigs can p i s s sideways when being transported
JonnyH
posted on 16/10/14 at 11:17 AM Reply With Quote
Thanks, that was quite an interesting read! I'll look forward to seeing it progress further!
I might well end up asking you more about what you did with the sump, the stock Renesis one is pretty shallow but i'm not sure if it's shallow enough...
Ben_Copeland
posted on 16/10/14 at 11:40 AM Reply With Quote
Whereabouts in Kent are you?
If you need any help with the chassis etc your welcome to look at mine.
I've also got a friend who's nutty about RX8s and is currently trying to turbo it
Ben
Locost Map on Google Maps
Enter Your Details Here
JonnyH
posted on 16/10/14 at 11:47 AM Reply With Quote
I'm in Eccles just up from Maidstone. But not for long, end of the month i'm relocating to a different site for work so will be off to Hampshire.
I'm planning to get a ready made chassis and just modify it where/if need be. Will save me a huge amount of time on the build and they aren't hugely expensive.
After i move my daily commute will go from a 20 mile each way drive to a 10 min walk. Very tempting to get rid of the old diesel Focus and have an RX8 as a daily driver
serieslandy
posted on 16/10/14 at 12:32 PM Reply With Quote
Where abouts are you moving to in Hampshire? You may be close to me.
JonnyH
posted on 16/10/14 at 12:34 PM Reply With Quote
I'll be in Bordon, about half way between Guildford and Portsmouth....
serieslandy
posted on 16/10/14 at 12:36 PM Reply With Quote
Not that far from me about 20mins.
If the weather was a bit nicer I would drive up to you once you've moved.
[Edited on 16/10/14 by serieslandy]
JonnyH
posted on 16/10/14 at 12:39 PM Reply With Quote
You'll have to forgive me in advance if I call on you for help from time to time
serieslandy
posted on 16/10/14 at 01:06 PM Reply With Quote
That's ok. Been there, done that. Although I did go the safe route with a sierra donor and the stock pinto.
When Saturn sports cars were about, Andy started to use an rx8 as a donor then changed direction with the mx5 instead.
Have you registered on The Haynes forum? It's been quiet lately but there is a wealth of knowledge specifically for the roadster.
JonnyH
posted on 16/10/14 at 04:32 PM Reply With Quote
I was tempted to go with an MX5 or maybe a bike engine. But both have been done a fair bit now and I'm a big fan of things that are more on the unusual side.
I thrive on a challenge, it's the engineer in me
I haven't looked at any other forums yet, I'm going to need to no doubt. Must get in the RX8 ones and problem them about the OMP.
JonnyH
posted on 17/10/14 at 12:12 AM Reply With Quote
Ok, so i might have just done something silly...
Threw a friend of a friend a mindt condition 13B REW engine came up for sale at a bargain price and I've committed to buying it!
So, my estimated 350bhp just jumped to a potential 500bhp
The thirst for power continues!
Adam R.
posted on 10/1/15 at 09:32 PM Reply With Quote
13B REW it`s not good idea
high power turbo rotary generate huge heat
in 7 style you don`t have enough space for coolers
