Author: Subject: Oxy acetylene alternative
speedyxjs
posted on 9/9/10 at 07:57 PM Reply With Quote
I encountered a couple of broken broken boltsn at work today that just would not budge with stud extractors etc so sfter 2 hours of trying to remove them, i took them to a mate who got them out with oxy acetylene.
Unfortunately, i can justify the costs of an oxy acetylene setup and bottle rental so i was wondering if any locosters knew of a way of getting similar heat from a much cheaper, workshop friendly source?
MakeEverything
posted on 9/9/10 at 07:58 PM Reply With Quote
Oxygen and Propane, or MAPP gas.
Kindest Regards,
Richard.
Mark Allanson
posted on 9/9/10 at 08:09 PM Reply With Quote
Carbon arc torch - loads of fun!
iank
posted on 9/9/10 at 08:18 PM Reply With Quote
Something like this would probably be the best bet
http://www.welduk.com/Details.asp?ProductID=198
Anonymous
will121
posted on 9/9/10 at 08:40 PM Reply With Quote
depends what you want to do with it, if just heating things up better than a blow lamp then i brought a MAPP gas torch goes up to 2000deg according to Wiki about £60 on ebay
posted on 9/9/10 at 09:08 PM Reply With Quote
Yes MAPP is a bit toasty Good enough for getting out crudy bolts. No good for welding but that's a different matter....
andkilde
posted on 9/9/10 at 11:00 PM Reply With Quote
Ask around with trade friends to see if they have a favorable contract rate they can add a set of bottles to for you, big plumbing and HVAC firms usually have a bunch of bottles on contract. My rental rate is $40 cdn, per bottle, $23/m^3 for acetylene fill and $38 for a full oxy top up. It's about triple that for the "man off the street" pricing. A set of torches regulators and hoses run $100 or so on fleabay. I take years to go through a set of bottles in my home shop but it'd drive me mad not to have them -- we use a lot of salt on the roads in winter so every fastener you touch is seized...
Cdn dollar is about £0.66 at the moment.
t
Dale
posted on 10/9/10 at 12:00 AM Reply With Quote
I braze and cut with oxy and propane.
Seems to go through about 2x the O2 as when using acetylene though.
Dale
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
speedyxjs
posted on 10/9/10 at 06:25 AM Reply With Quote
It is just for heating things up so i think mapp sounds like the way to go. Thanks for all your replys
posted on 10/9/10 at 06:36 AM Reply With Quote
there are these portapack - whatever they are called - small bottles of oxygen and acetylene, similar in size to the disaposable MIG gas cylinders/
but then you need the gear - torches, hoses, glasses etc. that will set you back over £ 100, not including the gas.
the map torch or 2 seems the way.
Mike S
posted on 10/9/10 at 08:22 AM Reply With Quote
I have got a set of proper mini gas cylinders with gauges and regulators (BOC) and torch which is surplus to requirements.
Still loads of gas in them. £75 collected from Sittingbourne, Kent if you are interested.
Mike
There are more horses' asses in this world than there are horses
