Author: Subject: Broken Stud Extractor Tool Recomendations
Doctor Derek Doctors
posted on 13/10/15 at 02:35 PM Reply With Quote
While taking the front exhaust pipe off my Alfa I have broken off two studs.
Can anyone recomend a stud exctractor tool/set for removing studs/threads where there is naff all sticking out to grab onto.
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
r1_pete
posted on 13/10/15 at 02:44 PM Reply With Quote
weld blobs onto the end of the stud until there is enough to put a nut over, then weld the nut on, and unscrew whilst its hot, the heat of the welding does also loosen the alloy / steel corrosion.
[Edited on 13/10/15 by r1_pete]
posted on 13/10/15 at 02:50 PM Reply With Quote
Check the studs are screwed these days on a lot of manifolds studs are pressed in from the back in the same way as Ford Sierra wheel studs
[Edited on 13/10/15 by britishtrident]
posted on 13/10/15 at 03:11 PM Reply With Quote
Its defo' screwed studs, I'm actually surprised that on a 20 year old Alfa Romeo that all 4 didnt snap off, 2 actually unscrewed.
Didnt think of the welding idea, will try that if I can get access.
www.t89.co.uk
callan@t89.co.uk
posted on 13/10/15 at 03:43 PM Reply With Quote
If the studs sheared off due to corrosion, then 'easyout' type stud extractors will almost certainly shear off as well, and make your life even more difficult. Either use the weld trick, or drill out the remaining stud. You may well need something better than HSS to drill them out though (e.g. cobalt drills) since exhaust fasteners can get extremely hard from the numerous temperature cycles.
ash_hammond
posted on 14/10/15 at 07:28 AM Reply With Quote
Nice idea, i will remember that.
.: www.mac1motorsports.co.uk | www.m1moc.com :.
posted on 14/10/15 at 05:35 PM Reply With Quote
Works with brake pipe nuts, bleed nipples, wheel bolts , sump plugs and cylinder head bolts as well
posted on 17/10/15 at 07:43 PM Reply With Quote
A MIG welder is good for removing wheel bearings as well
[Edited on 17/10/15 by MikeRJ]
Staple balls
posted on 17/10/15 at 09:38 PM Reply With Quote
Not massively useful (i'd go with the welding a nut on, absolutely the best way to do the job)
But, interesting as a solution to these issues.
[youtube]https://www.youtube.com/watch?v=7pN-fnUeA3o[/youtube]
indykid
posted on 17/10/15 at 10:10 PM Reply With Quote
If you can't get at it with a welder, or it's a temperature sensitive component, you won't find a better set of stud extractors than these
Not cheap, but bloody good. Drill the hole, knock in the splined shaft, slip the driver over the top and ease the stud out. It's rare that they don't work, even for getting studs out of turbine housings.
First time I had to do something like this I used a stud extractor and it sheared and It was a right royal pain to then drill out.
Second time I used the nut and weld job. Worked first time. ...
Nuff said?
posted on 18/10/15 at 10:48 AM Reply With Quote
Nuff said?
Stud extractors have their place: if you have a sheared fastener caused by fatigue or over-tighening then stud extractors can work very well. If you have sheared a fastener because it's locked solid with corrosion, they don't.
posted on 18/10/15 at 02:08 PM Reply With Quote
Absolutely- it was my own fault being a savage and using the wrong tool. Stud extractors are good for not seized but snapped-off flush stuff. Although I've yet to experience that- with me it's always seized solid stuff! The nut thing works wonders IMHO.
posted on 18/10/15 at 02:35 PM Reply With Quote
I'm not a great fan of any type of stud extractors , I have a set of the Ridgid splined extractors but as said if the stud is seized forget them . For stud that don't appear to be seized left I have a set of cobolt left hand drill bits that work well but still tend to use the mig if I can get to the remains easily. Right angled air drill helps to get into difficult places
