Author: Subject: 2015 suzuki vitara allroad
omega 24 v6
posted on 24/10/22 at 05:37 PM Reply With Quote
Hi guys it's been quite a while since I was on here. The font of all knowledge as I remember.
So with that in mind here goes.
My daughter has a vehicle as above. The new style vitara. The issue is this
Low speed 15 to 25mph vibration which goes away after this but is left with a growly bearing type noise.
We're thinking prop bearing or Hardy spicer but I've not been under it yet. We think at those low speefs it's unlikely to be drive shafts ,as at The low speed they'd be lucky to be turning at 20rpm (guessing).
Do we know if this vehicle is permanent 4wd?
Could we disconnect and remove prop for diagnostic purposes or would it lose drive due to an open diff.
If so we could tow it to simulate roadspeed as the engine would be running for brake servo to work.
Discuss.
Thanks in advance guys and galls.
adithorp
posted on 24/10/22 at 07:26 PM Reply With Quote
Just get under and feel for play in the drive shaft uj's.
http://jpsc.org.uk/forum/
omega 24 v6
posted on 24/10/22 at 07:47 PM Reply With Quote
I will be when she brings it over tomorrow
Just sounding out for ideas
Thanks.
Prof_Cook
posted on 24/10/22 at 08:23 PM Reply With Quote
Had similar noise on a relatives car. Jacked up each corner of car in turn (with axle stands) and found a very slack wheel bearing could wobble the wheel some 8mm to-fro....
[Edited on 24/10/22 by Prof_Cook]
omega 24 v6
posted on 26/10/22 at 05:28 AM Reply With Quote
Rear Hardy spicer seized solid.
