carcentric
posted on 13/4/04 at 03:00 AM |
Direction of driveshaft rotation
I was looking at a BMW (320?) differential today and noticed that - from the engine end of the diff - when I turn the input (propshaft) flange
counterclockwise, both output (axle) flanges turn together in the forward direction, and when I turn the input flange clockwise, both output flanges
turn together in the reverse direction.
Isn't that backwards from US and British differentials? I think to get their output flanges to turn forward, you turn the input flange
clockwise. I know it's that way with my Triumph Spitfire differentials.
M D "Doc" Nugent
http://www.carcentric.com
theconrodkid
posted on 13/4/04 at 07:18 AM |
you got the diff upside down?afaik they all go in the same direction
who cares who wins
pass the pork pies
carcentric
posted on 13/4/04 at 05:40 PM |
Upside down?
I'm assuming this is the topside (see picture) - it has the BMW logo and part numbers cast in - but I'll look for a vent hole (that should
be on the top if there is one).
M D "Doc" Nugent
NS Dev
posted on 13/4/04 at 11:52 PM |
They do NOT all go in the same direction, so nobody has been silly here, although BMW do go in the "normal" direction. Honda however, have
engines which run in the reverse direction to anybody else's, so their diff's are the opposite way around!!
theconrodkid
posted on 14/4/04 at 06:01 AM |
according to my book of words the mounting lug on the side goes to the left side of the car,so looks like you had it upside down
who cares who wins
pass the pork pies
posted on 14/4/04 at 08:42 AM |
i was going to say, the writing could well be on the bottom cos that where it will be visible when mounted!
carcentric
posted on 14/4/04 at 11:31 PM |
Mystery solved (color me embarrassed)
Yep, I've been storing it upside down since I got it (it was abandoned by a former tenant who skipped without paying the back rent).
Found the vent, what I thought was a fill plug turned out to be a drain plug, even found the ring tooth and pinion tooth numbers stamped in the side .
When right side up (vent on top, numbers down), it turns the same way as other differentials.
Live and learn.
M D "Doc" Nugent
