New Topic New Reply
Author: Subject: Small Fabricating help needed
Jasper
posted on 30/1/09 at 01:36 PM Reply With Quote
I need to make up a couple of bits for my seat belts. As it is they clamp up solid at the hips (designed for a single seater) but I want them adjustable.
So, can anybody make these up for me? I would attempt it in the garage with a drill and grinder, but it would be much better if they were laser cut if it's not too expensive.
Ideally galvanised but I can get that done locally if not.
They need to be around 4mm thick, the rest of the dimensions are on the picture. The slots are too narrow (2 inch - 50mm) in the ones I have. Rescued attachment ABCD0020.JPG
Jasper
posted on 30/1/09 at 01:37 PM Reply With Quote
madrallysport
posted on 30/1/09 at 01:39 PM Reply With Quote
u2u sent to ya
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
madrallysport
Sorry double posted
[Edited on 30/1/09 by madrallysport]
Jasper
posted on 30/1/09 at 01:45 PM Reply With Quote
Thanks mate - your a star Knew I you trust you guys on here.....
New Topic New Reply
