Author: Subject: Brand new Westfield SEi WIdebody Rolling Shell
DannyScarbro
posted on 20/8/16 at 11:41 AM Reply With Quote
Have available for sale a Brand new Westfield Sei Widebody rolling car, including a 1993 logbook.
Purchased and built up over the last year as per my build thread. http://forum.wscc.co.uk/forum/index.php/topic/110326-westfield-16-race-car-full-rebuild-with-honda-k20/
Brand New Westfield Sei Widebody Starter kit in White gloss
inc;
1 SPACE FRAME CHASSIS
2 TOP FRONT WISHBONES
3 BOTTOM FRONT WISHBONES
4 ENGINE MOUNTING BRACKETS
5 PEDAL BOX INC. MASTER CYLINDER/FLOOR MOUNTED
6 BRAKELINES, AEROQUIP & TEE PIECE
7 ALUMINIUM PANEL SET INC.
FLOORPLAN, SEAT-BACK, TUNNEL & SCUTTLE
NUTS, BOLTS, RIVETS & SUSPENSION BUSHES
& CHASSIS PLATE
8 WING BRACKETS
REAR DISC BRAKE UPRIGHTS
WESTFIELD BAR SHAFT WITH CIRCLIPS
HUBS WITH STUDS
HANDBRAKE CABLE
9 BOTTOM REAR WISHBONES
10 TOP REAR WISHBONES
11 TOP STEERING COLUMN AND LOCK 4 x SPHERICAL JOINTS
12 BODY KIT- REAR BODY SECTION,
SCUTTLE, BONNET NOSE, SCREEN FILLET, BADGES
I then paid for the following extras;
DETACHABLE ARCHES (UPGRADE).............................. £250.00
SHOT BLAST & POWDER COATING
OF CHASSIS (0618004)............................................... £230.00
POWDER COATING OF SUSPENSION PARTS
IN STARTER KIT (0618012)............................................. £90.00
FIT AND SEALING OF ALUMINIUM
PANELS (0677127)...................................................... £325.00
FIT BRAKE LINES TO CHASSIS (0677004)..................... £95.00
FIT 2 FUEL LINES TO CHASSIS (0677047)..................... £75.00
FIT WESTFIELD WIRING LOOM (0677112)...................... £95.00
FIT RIVNUTS TO CHASSIS (0677020).............................£41.00
WIDE TRACK FRONT WISHBONE UPGRADE................. £225.00
S2000 BONNET UPGRADE............................................ £200.00
WRRING LOOM FOR CHASSIS.................................£313.00
WIRRING LOOM FOR S2000 ENGINE.......................£70.83
FITTING OFF WIRRING LOOM..................................£95.00
This all cost me well over £6k
On top of this I have fitted the following upgrades/parts;
-Carbon fibre race front wheel arches
-Caged full roll cage
-Pro-tech Adjustable coilovers (300miles from new)
-Playskool motorsport front & rear Anti roll bars
-Mi16 front calipers with Mintex pads and braided hoses.
-13x7" Team dynamics gloss black pro race wheels
-Toyo 888 185 front 205 rear tyres (loads of tread left)
-Spacers for perfect arch fitments
-SPA suede steering wheel (brand new)
Again another £3,000 spent and lots of time fitting it all together!
This is perfect for someone who wants to build a brand new Westfield, it will save you a fortune on buying it all new & still leave the option of running gear and nice finishing touches to you to make it your own.
£6,000.
Available with the following additional bits if wanted;
-Brand new carbon fibre dash with second hand Dash Pro digital dash fitted for an extra £550
-Quaife ATB Sierra Diff with 4.1 FD and in casing fitted for £850
-Hi Spec R1-114 race 282mm BIG Brake upgrade with lightweight floating disks fitted - £700
OR all the above for £8,000.
Any questions feel free to call, am open to adding/taking off bits for different prices.
07867 384175
Many thanks
Dan
DannyScarbro
posted on 20/8/16 at 07:36 PM Reply With Quote
Deposit taken now. Thanks
