<<  1    2  >>
Author: Subject: More help needed with my scooter project - chain this time
mad-butcher
posted on 6/5/12 at 11:34 AM Reply With Quote
maybe I'm missing something but if it's rigid rear end then chain angle doesn't matter as it's in constant tension ( as in a chain drive diff ) to tension/adjust the chain, you only really need say 2 links play can you not slot the mounting plate for the rear axle bearing carriers
ChrisW
posted on 6/5/12 at 11:37 AM Reply With Quote
The problem was more that with the tight chain angle I was worried that it would hit the engine casing, but I think I've resigned myself to the idea that, if it proves necessary, adjusting the clearance using an angle grinder isn't the end of the world. I didn't really want to do it that way, but it's a whole load of effort to go to for a 'proper' fix.
Chris
My gaff my rules
Confused but excited.
posted on 6/5/12 at 11:56 AM Reply With Quote
If you are worried that a plastic guide wheel will wear, why not just use a small free-running sprocket?
Fred W B
posted on 6/5/12 at 04:03 PM Reply With Quote
Gearing sounds right now.
I would also prefer a proper idler sprocket, rather than a plastic roller.
With such a short chain run, you have to be carefull to keep the sprokets well aligned in the longitudinal direction. It is easier to move the engine to adjust the chain slack, rather than trying to keep the axle square in the chassis if you move that for chain adjustment.
With the solid axle you need to keep the axle square in the chassis so that the contraption runs straight.
Fred W B
[Edited on 6/5/12 by Fred W B]
<<  1    2  >>
