Viper
posted on 11/4/04 at 08:21 PM |
HELP..........
anybody out here ever changed a steering rack on a cavalier??? is there an easy way to remove the bolt under the servo??
Tim
theconrodkid
posted on 11/4/04 at 08:39 PM |
what sort of cav?pas?never had a prob with them
who cares who wins
pass the pork pies
Viper
posted on 11/4/04 at 08:44 PM |
PAS 20 saloon fwd, the u clamps that hold the rack to the bulkhead, o/s, top bolt is behind the servo can't get on the poxy thing, can't
get on the bolts for the servo either......
Ben_Copeland
posted on 11/4/04 at 09:34 PM |
Should beable to unbolt the servo from the bulk head. It says in the haynes manual that you need to remove the servo! Its a complicated process!
buy a haynes manual it talks you through it
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
Wadders
posted on 12/4/04 at 12:06 AM |
This is going to sound like no help at all, but it is definately possible to change the rack without removing the servo, i did it once, many years
ago, so long infact that i can't remember how. I do remember it was a proper basta*d of a job and thinking it was impossible, and then finding a
way to do it. I seem to remember finding two holes and using a long allen key to undo a couple of bolts holding the servo. Make sure you flush out the
fluid tank and pipes, i forgot, and the new rack sprang a leak within a few days which was VERY depressing.
Good Luck
Al.
theconrodkid
posted on 12/4/04 at 06:54 AM |
think last time i did one i just removed the bottom nut and bent the clamp till it slid round the rack.i used the U/J and socket all in one peice
who cares who wins
pass the pork pies
Viper
posted on 12/4/04 at 07:48 AM |
The bolt in question hits the servo before it is fully undone, in fact after about 2 turns, i got the rack off with the aid of an air saw its just
getting the replacement back on. for the record it onlt took five sore and bloody hours to remove one pissin bolt..is rhis a record???
Tim.
