Author: Subject: Spare Blades for exhaust pipe cutter
davidimurray
posted on 14/12/14 at 10:09 PM Reply With Quote
Does anybody know where you can spare blades for one of these?
http://www.silverlinetools.com/en-GB/Products/Automotive/Engine%20and%20Drivetrain/739592
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
steve m
posted on 14/12/14 at 11:22 PM Reply With Quote
I know B&Q did replacement blades for pipe cutters,
may be usable ?
CosKev3
posted on 14/12/14 at 11:27 PM Reply With Quote
Have you got a local pikey/traveller camp?
If so go see them, aledgedly this is the tool they use to steal cats off cars
rdodger
posted on 15/12/14 at 08:54 AM Reply With Quote
Your local plumbers merchant should be able to help with pipe cutter blades.
r1_pete
posted on 15/12/14 at 11:12 AM Reply With Quote
Screwfix have them, although not far off the price of a new cutter.
davidimurray
posted on 15/12/14 at 12:19 PM Reply With Quote
Will those general pipe cutting blades work for steel tube or is it just copped etc. I did two cuts on a nasty old exhaust pipe under my car and the blades were knackered!
rdodger
posted on 15/12/14 at 03:11 PM Reply With Quote
I have used my Rothenberger pipe cutter many times to cut 18-20mm 1.5mm steel tube with no issues. I guess the blades are a bit better than cheap exhaust cutters.
