jacko
posted on 27/3/07 at 08:58 PM |
vectra fog lamp
Hi all i have a vectra 04 it is a cdti sri 1.9 it has 2 fog lamps but only one is wired up from new. it is it,s first mot on thursday. will it
pass like this ? i thought if a lamp was fitted it had to work can some one check on there car and let me know please
Graham
Rek
posted on 27/3/07 at 09:20 PM |
Got an 02 plate with the same thing. It's passed twice.
TGR-ECOSSE
posted on 27/3/07 at 09:25 PM |
You only need one fog light for an M.O.T. but it must be the o/s one.
bigrich
mot min requirement is a fog lamp fitted to the centre or o/s of vehicle.
lots of vehicles only have one lamp wired up as standard.
graememk
posted on 27/3/07 at 10:57 PM |
most cars only have one fog lamp, when i wrote to vauxhall about this (i was bored) they sent me a letter back saying that its done as they feel its
safer as they dont think people will confuse it with brake lights with only one being lite as it stands out more
tks
posted on 28/3/07 at 12:57 AM |
mhhh
on my corsa i thought the same
when i came to a closer look i saw that the unit looks the same
but it isn't sow in fact you think you have to bulbholders but only one actualy holds a bulb and is able to hold one..
Tks
Humbug
posted on 28/3/07 at 05:48 AM |
My Passat estate has 2 bulbholders but only one bulb. Same on a Golf my bro had. Cheapskates!
jacko
posted on 28/3/07 at 03:48 PM |
Thankyou for your help
Graham
posted on 28/3/07 at 07:01 PM |
Lots of modern cars have the lamp capable of taking a bulb holder for the N/S rear fog light but the lamp does not have a reflector
Mark Allanson
posted on 28/3/07 at 07:09 PM |
Its all for a reason, if the bulb goes while in use, then you take potluck about being hit, if you have twin fogs and the RH one fails, then a driver
behind may be fooled into thinking that your car is one car width to the left... weak, but that is the thinking
