grassracer
posted on 28/3/07 at 11:59 AM |
How do you free a seized clutch
I've just gone back to our Ducato camper after it sitting since the turn of the year and the clutch is seized ie it wont engage/disengage on
pressing the pedal.
Is there anything I can try to free it off without removing the gearbox??
Mr Whippy
posted on 28/3/07 at 12:03 PM |
jack up a drive wheel then put it in 3rd ,start it in gear and rev up the engine (take it up to 70 or so on the speedo). Then jump on the brakes,
after a few goes it will break free. Once free slip the clutch a bit to buff the rust off.
I've had to do this many times in the past.
[Edited on 28/3/07 by Mr Whippy]
locoboy
posted on 28/3/07 at 12:04 PM |
Maybe try starting it in neutral and seeing if the vibration from the running engine is enough to free it off????
Failing that is there an inspection cover / plate?
if so maybe a drift in the cover and bive the flywheel / clutch a tap???
Locoboy
whitestu
posted on 28/3/07 at 12:17 PM |
Have you tried to free it off using the starter, with the brakes on?
Stu
Mr Whippy
posted on 28/3/07 at 12:19 PM |
I think the main thing to remember is if the cars sitting for a while press the clutch every month to avoid it sticking
Mr Whippy
posted on 28/3/07 at 12:26 PM |
Stu
ehm, 'click' as all you'll hear...then you'd smell smoke
whitestu
posted on 28/3/07 at 12:57 PM |
It's worked for me in the past - obviously if it doesn't free then don't keep the starter on. Starter motors are quite tough - It
won't immediately go up in smoke.
Stu
grassracer
posted on 28/3/07 at 01:32 PM |
The Whippy method works for me , first time....thanks guys!
thomas4age
posted on 28/3/07 at 01:35 PM |
I tried all these thing a few years back on my striker, but none of them worked,
the last thing I could think off befor pulling the engine out was, Jack up the car at the front so you can get to the bellhousing, then look for any
hole through which you can see the clutch and presure plate (clutch fork hole in my case)
fully press the clutch pedal and keep it pressed (wooden stick did the trick)
Now crawl under the car with a scredriver (flat one) and a small hammer try to put the screwdriver inbetween the clutchplate and the flywheel, tick it
with the hammer then turn the crank a few degrees and repeat until you're certian it's not sticking to the flywheel anymore, repeat this
for the presure plate, (80% gues that it's stuck to the flywheel and not the presure plate)
let the clutch slip to remove the dust and off you go again. 20 minute job and no risking of breaking something else
grtz Thomas
If Lucas made guns, Wars wouldn't start either.
Mr Whippy
posted on 28/3/07 at 01:40 PM |
cool
Macbeast
posted on 28/3/07 at 04:01 PM |
I've heard - with engine off put it in top or third and try to rock car backwards and forwards with clutch pedal pressed. (It would help to be
parked on the level )`
This also works for jammed starters.
mark chandler
posted on 28/3/07 at 07:37 PM |
engine off, third gear, clutch depressed tow it around the block.
Regards Mark
