Author: Subject: BIG FAT SILENCER
Steve (dug) Richards
posted on 19/9/07 at 03:55 PM Reply With Quote
BIG FAT SILENCER
I was wandering if anyone knew where i could get a nice quiet can for my indy i am running a 05 R1 with mks manifold which has a 2inch pipe to bolt on to.
And if you read this kev there not gay
stevec
posted on 19/9/07 at 04:05 PM Reply With Quote
The one Here Cost £90 including the turned and radiused outlet. It is very quiet.
Steve.
Andy W
posted on 19/9/07 at 04:10 PM Reply With Quote
How about a R1 Can?
Pinto starter 1
Pinto starter 1
TimC
posted on 19/9/07 at 04:35 PM Reply With Quote
You want to go REALLY big with that high reving bike motor. I'm trying to think of the name that all the Westfield Sprint guys use. Tech..summat... Dammit can't remember, but think HUUUUGE!
Furry
posted on 19/9/07 at 05:03 PM Reply With Quote
hi tim,
i think your thinking of tech craft. i intend to fit one on my westy.
furry
Toady1
posted on 19/9/07 at 07:35 PM Reply With Quote
yeah they are huge, and great for trackdays, but not very locost iirc! Not that mine has turned out to be either! lol!
Toady1
posted on 19/9/07 at 07:36 PM Reply With Quote
Steve.
pretty sure that wont quieten down a bec enough!
ChrisGamlin
posted on 19/9/07 at 07:40 PM Reply With Quote
Mine's a 29 x 7" Simpson silencer which does a good job on my '03 R1, cost about £220
Anything sub 6" and/or shorter than about 25" maybe OK on turbocharged cars etc, but it isn't going to silence a BEC sufficiently unfortunately.
stevec
posted on 19/9/07 at 07:53 PM Reply With Quote
Steve.
It dosn't have to be big to be efficient.
The R1 Can on my bike engine car only just scraped trough SVA.
Steve.
Avoneer
posted on 19/9/07 at 07:54 PM Reply With Quote
Chris - what sort of db does your can give and what's the sound/performance like?
Pat...
ChrisGamlin
posted on 19/9/07 at 08:30 PM Reply With Quote
Steve.
Hi Steve
A small silencer can be quiet fairly easily, and a small silencer can be free flowing, but Ive yet to see one that does both.
Its worth remembering about the R1 cans as well that they fairly quickly degrade and get quite noisy. You could have picked up one that was already on its way out because people have got normally aspirated BECs through SVA with an R1 can, so a turbocharged car like yours (where the turbo absorbs a lot of the noise) is very unlikely to be louder I wouldnt think, certainly with a friend's BEC turbo busa its significantly quieter now with the turbo despite running the same silencer etc.
cheers
Chris
[Edited on 19/9/07 by ChrisGamlin]
ChrisGamlin
posted on 19/9/07 at 08:37 PM Reply With Quote
Pat...
Hi Pat,
Ive not been on a trackday that has tested it properly yet but I tested it myself with a noise meter I borrowed that's at least as good as those used on most trackdays and it was between 96-97db at a true 8,000rpm, so will be lower than that on most 3/4 tests where you can generally get away with 7 - 7.5k. With the knackerd R1 can it was about 105db!
Also this is with an open sausage filter and a hole in the bonnet so Im getting a lot of induction noise in there, I reckon with a proper airbox I could get that down below mid-90's quite easily.
cheers
Chris
stevec
posted on 19/9/07 at 08:46 PM Reply With Quote
Steve.
Hi Steve
cheers
Chris
Good point. No wonder my ears are still ringing 6 months on
Steve.
Gixer Indy
Contributor
Posts 85
Registered 18/7/07
Location Zummerzet
Member Is Offline
Photo Archive Go!
Building: a dislike for people using washers when im behind
posted on 20/9/07 at 09:08 AM Reply With Quote
Originally posted by Andy W
How about a R1 Can?
Pinto starter 1
Pinto starter 1
Just put one of these from Andy on mine, very pleased with it, no more bleeding ears!
Flat out til you see God, then BRAKE!
CosKev3
posted on 20/9/07 at 08:22 PM Reply With Quote
Just cause your over 30 now doesn't mean you have to act like an old man!!!!!
You need a nice sounding sporty exhaust note,not a quiet one
Leave it alone
Toady1
posted on 20/9/07 at 09:08 PM Reply With Quote
i have a remus back box on mine which looks very similar in size to yours steve, i failed the noise test at my last trackday at 103db, and that was with me gutting the original sound wadding, and repacked it with a full bag of merlin motorsports stuff. had to put a tail piece thing on it to get back on track!
Im going to go for something like you have chris!
TimC
posted on 21/9/07 at 11:08 AM Reply With Quote
Tech Craft - that's the fellas.
ChrisG's performance? - pretty bloody good if you look at the Cadwell videos!
ChrisGamlin
posted on 21/9/07 at 10:38 PM Reply With Quote
Cheers Tim, was a good day that. Sadly the Spa ones aren't quite so good!
