ttalps2000
posted on 3/11/17 at 09:50 AM |
Zetec water pump outlet size
Can anyone confirm what the diameter of the outlet size is from a silvertop zetec water pump? (fitted to the engine, not external like the
blacktop)
I think it is 45mm diameter! Need to get a hose!!
bonzoronnie
posted on 3/11/17 at 02:07 PM |
Just checked the outlet of my 1.8 silvertop engine
New aftermarket pump, measures 44mm Past the bead & To the nearest mm
I guess 45mm id pipe is the correct size for the water pump hose.
[Edited on 3/11/17 by bonzoronnie]
jossey
posted on 3/11/17 at 07:03 PM |
Same in my 2.0*silvertop
David Johnson
