macspeedy
posted on 25/4/03 at 04:02 PM |
Pinto question
Does the pinto engine have to have a breather going from the rocker cover or oil filler cap to anywhere?
Viper
posted on 25/4/03 at 04:23 PM |
Ideal place would be to your air box but i bet you re not using an air box ae you...so to a catch tank that has vents in it,
geoff shep
posted on 25/4/03 at 04:55 PM |
No.
Well, neither of mine have.
posted on 25/4/03 at 05:41 PM |
It's in the oil filler cap.
There is wire mesh inside mine and the manual says to clean it with paraffin.There's a vent valve on the oil seperator but that connects to the
manifold.
yours, Pete.
macspeedy
posted on 25/4/03 at 06:10 PM |
surely the fact that the oil runs out one end into the crank case that is adequate for the air to circulate as well ? i had thought about the boxes as
I am unsure on how 45's fit under an MK bonnet. such as boxes that Ca.. do but at a fraction of the cost check out http://www.plays-kool.co.uk/
download brochure and enjoy unless anyone else has another suggestion/ supplier?
