Author: Subject: Pinto Engine Stamp
tubage
posted on 8/8/03 at 12:07 PM Reply With Quote
Pinto Engine Stamp
I have a third hand pinto Engine. It's a 2.0 205 Block. According to June Which Kit I should be able to tell if it's High or Low Compression from the Engine Stamp Number. Mine begins with HK which is not listed on the 'handy' table'. Also in the Which Kit MK build Dr Watson suggests that if the head begins with P then it can run on unleaded. What I want to know..is my engine High Compression and would it be problem if it wasn't....and..as my head cast number is P8 can it run on unleaded. The Engine is from a 'D' Reg if that's any help. On the whole the Engine looks good. I think the Cam shaft has been replaced recently, The Spray bar looks new and the gasket very fresh. ...but then what do I know??
dave blissett
posted on 15/8/03 at 08:07 PM Reply With Quote
compression
the compression is down to piston heights from the pin to the top of the piston
Mark Allanson
posted on 16/8/03 at 09:41 PM Reply With Quote
I don't know about the compression, but the engine is Feb 87 if its any help
matt_claydon
posted on 16/8/03 at 10:13 PM Reply With Quote
The code you are after is not the usual 'Engine Number' stamp, but a three (?) character code stamped on the gearbox mounting flange (took me ages to find mine, I didn't know exactly where it should be and it was covered in grime!):
A comprehensive table of what this code means can be found here:
http://home.att.net/~CapriClubChicago/engcode.htm
Ignore the first table, it's the second two tables we are interested in.
It's only the first two characters that are important.
HTH,
Matt.
[Edited on 16/8/03 by matt_claydon]
tubage
posted on 26/8/03 at 12:01 PM Reply With Quote
Thanks All, I had the V55 so knew the age. Turns out it's a high performance, twin carb model....lovely.
Any body have any thoughts on the unleaded issue??
[Edited on 26/8/03 by tubage]
Dusty
posted on 26/8/03 at 08:29 PM Reply With Quote
Code NR or N4 on the flange Matt's pointer goes to indicates the engine was originaly built for injection 2L, NE for carbed 2L. There is a separate code stamped on the head, either on the inlet or exhaust manifold gasket face, gearbox end. L, P, PP, R, or RR indicate the head is OK for unleaded. Injection heads with the pear shaped inlets are all OK for unleaded.
tubage
posted on 27/8/03 at 07:25 AM Reply With Quote
Thanks Dusty. I have a P.
So does that mean my Head is OK for Unleaded...without any modifications or special fuel additives? Thanks for you help.
Dusty
posted on 27/8/03 at 11:03 AM Reply With Quote
Yes, if its stamped on the manifold face of the head.
tubage
posted on 27/8/03 at 11:55 AM Reply With Quote
Superb, I'll paint it then and whack it in. Might treat it to some Super Unleaded...
Thanks All.
