Author: Subject: Pinto tidy up almost complete
ragindave
posted on 18/12/08 at 12:00 AM Reply With Quote
Rob do you recognise this engine?
[Edited on 18/12/08 by ragindave]
omega0684
posted on 18/12/08 at 12:25 AM Reply With Quote
OOOOOOOOOOOOOOOOOOOOOOOOOO SHINEY!
skodaman
posted on 18/12/08 at 12:44 AM Reply With Quote
What did you paint the block with? My crossflow looked like that till I was forced to keep it outside under plastic bags for two years
Skodaman
Dusty
posted on 18/12/08 at 01:07 AM Reply With Quote
Beautiful pinto. Love it but not keen on the individual filters. They look great but they throw away power compared to a set of trumpets and a big pipercross sausage.
Daddylonglegs
posted on 18/12/08 at 03:55 AM Reply With Quote
Oh Poo!
Don't think I can ever look my pre-strip Pinto in the gasket ever again
How many hours of work went into that then?
Looks pretty damn pretty .
Mr Whippy
posted on 18/12/08 at 07:18 AM Reply With Quote
v I like that
jabbahutt
posted on 18/12/08 at 07:52 AM Reply With Quote
cracking job!! looks the dogs. Forgive my ignorance but I take it that they're bike carbs? if so what off and are they relatively easy to set up?
Nigel
Danozeman
posted on 18/12/08 at 08:05 AM Reply With Quote
Looks good matey.
Dont want to put a downer on your nice engine but them filters will zap some power as they dont flow air aswell as a sausage type! Nice manifold aswell btw is it bogg bros?
Dan
mcerd1
posted on 18/12/08 at 12:17 PM Reply With Quote
looking good - and strangly similar to what I'm trying to do
I'll have to work a bit harder on mine to keep up
[Edited on 18/12/08 by mcerd1]
ragindave
posted on 18/12/08 at 12:18 PM Reply With Quote
The engine was degreased and treated to paint stripper using a stainless pad to agitate the old paint.
The engine was sprayed using 1 tin of tetrosyl brush on enamal with 10% thinners and cheap spray gun.
The inlet manifold is another boggs master piece.
Rocker sump and pulleys shot blasted and powder coated silver.
Air filter may be revised I may be able to keep inside the bonnet with an itg 25mm sausage filter.
Next major job is getting it to spark using megajolt..
mcerd1
posted on 18/12/08 at 12:21 PM Reply With Quote
in fact thats identical to mine (apart from the colour)
Daddylonglegs
posted on 18/12/08 at 12:39 PM Reply With Quote
Pah! You think you've got some catching up to do....Mine
mcerd1
posted on 18/12/08 at 01:32 PM Reply With Quote
<<< mine started like that (or worse) just look at my avitar click
so far I've only added about 10 - 15 hours work to that
(+ a fair bit ££ of the internals, but you can't see them once its done)
I got the block chemicaly dipped (it was getting rebored anyway) - even after that I still had to spend a few hours with wire brush thing on the drill to clean up the outside, but it was much easier
posted on 18/12/08 at 01:52 PM Reply With Quote
wow that is far too lovely and shiney for something that will sit at the bottom of the sea!!
robbydee
posted on 21/12/08 at 07:55 PM Reply With Quote
is that a self made mod to the dizzy?
would like to do that too.. tidy.
jacko
posted on 22/12/08 at 04:56 PM Reply With Quote
Sorry but why O why did you not remove the ugly bracket that use to hold the old air box also will the oil filler be ok to miss the body
I must say that is one if not the nicest cleanest pintos i have seen
well done
Jacko
jacko
posted on 22/12/08 at 05:00 PM Reply With Quote
Thats how i did mine
Jacko
engine  2
engine 2
