Author: Subject: Pics of mid-engined home builds wanted
CraigJ
posted on 26/1/09 at 11:37 AM Reply With Quote
Im after some pics or build blogs of home build mid engine cars. Not kit cars though but actual cars converted to mid-engine. The main thing i want to see is how the rear suspension has been built or modified.
Cheers Craig.
posted on 26/1/09 at 12:09 PM Reply With Quote
New issue of PPC has a nice mid engined student project. It is a modified locost design with the passenger cabin moved forward to accomodate a Toyota engine in the back. Looks quite impressive naked.
Mr Whippy
best bet depending on the 'actual car' in question of course and especially if the car also has front and rear struts, would be to transplant the whole front suspension and subframe to the back and then fix the track rods to the inner wings to use as toe in adjustment. Most difficult job would be to sort out the gear linkages but you could use the cables used for speed boat outboard steering for that and a bit of ingenuity.
Alan B
posted on 26/1/09 at 12:49 PM Reply With Quote
Here you go...these are mine...
http://www.desicodesign.com/meerkat/index.html
http://www.tiki-cars.com/
kb58
posted on 26/1/09 at 02:29 PM Reply With Quote
Do you want actual cars that have been converted or are scratch-built cars acceptable, too?
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
short track 123
posted on 26/1/09 at 03:31 PM Reply With Quote
Hello Kurt
I have a copy of your book "Kimini" will you be doing a book of the new car ?
If so mark me down for a copy
Jason
kb58
posted on 26/1/09 at 05:45 PM Reply With Quote
The next book is in the works, check out the midlana.com site.
