Author: Subject: 1600 cross flow
Spritely
posted on 12/2/04 at 12:49 PM Reply With Quote
1600 cross flow
If I'm buying a 1600 cross flow, how can I tell the difference from a 1300.
What, if any, variants are there of the 1600 and how can I tell difference just by looking.
Les
posted on 12/2/04 at 06:50 PM Reply With Quote
1600 CROSS FLOW
1600 cross flow should have 711M-6015-B-A cast onto side of cylinder block 1300 should have 711M-6015-A-A . If your are looking for a 1600 I have a complete one for sale , but it will need a rebuild, rusty
Spritely
posted on 12/2/04 at 07:39 PM Reply With Quote
Rusty Nuts, sent you a U2U
Les
posted on 12/2/04 at 08:51 PM Reply With Quote
1600 CROSS FLOW
Spritely, have replied U2U, Rusty
JJM
posted on 12/2/04 at 09:26 PM Reply With Quote
Look at the front of the engine, where the thermostat housing is-a 1300 will not have much metal above this to the bottom of the head, whereas a 1600 will have about an inch of metal between the thermostat housing and bottom of head. Does that make sense??
theconrodkid
posted on 12/2/04 at 09:32 PM Reply With Quote
the gap between water pump n stat housing is 2 fingers wide on 1300,4 on 1600
who cares who wins
pass the pork pies
Spritely
posted on 13/2/04 at 02:27 PM Reply With Quote
1600 X-flow
What is dimension from bottom of block to top of rocker cover and also bottom of block to bottom of sump.
Les
