Author: Subject: What cars were 1600 x-flow fitted to?
MB
posted on 24/2/04 at 08:41 PM Reply With Quote
I eventually want to replace my 1100cc x-flow with a larger cc engine preferably a 1600 unit.
Does anyone know which Fords these were fitted to? I only know they were in some of the Escort 1 and 2s. Would be useful to know when I'm on the phone to scrap yards....
Alternatively, is there anything that can be done to my 1100 to make it a larger cc? I suspect it would need lots of bits replacing...
posted on 24/2/04 at 09:21 PM Reply With Quote
1600 CROSS FLOWS
1600 cross flows fitted to mark 2 and mk3 cortinas, capri's , some transit's and fiestas and also some morgan's, lotus's , tvr's to name a few, hope this helps
P.S. Have a 1600 , 711 engine in need of rebuild for sale , was running up until november, has low oil pressure
Mark Allanson
posted on 24/2/04 at 09:24 PM Reply With Quote
Don't forget the escorts!!
Beware the really early xflows, mid way through the mk2 cortinas, they were 3 bearing crank - bad news!!
posted on 24/2/04 at 09:32 PM Reply With Quote
1600 cross flows
M.B already mentioned the escorts, the 711 block is the one to look for . Rusty
MB
posted on 25/2/04 at 06:54 PM Reply With Quote
Is it the 711 block that had 5 bearings?
Can you tell from the casting / engine number what cc the engine is?
Rusty, I've sent you a u2u about your engine that needs rebuilding. I quite often make my way over to Cottenham near Cambridge...
posted on 25/2/04 at 07:10 PM Reply With Quote
M.B Have replied to your u2u.
Rusty
david walker
posted on 29/2/04 at 08:53 AM Reply With Quote
All X'Flow blocks from all car models had 5 bearing cranks. Some of the old pre x'flow stuff such as the Ford Classic 109E were 3 bearing.
By the way anyone got any 109E blocks for sale?
Dave Walker, Race Engine Services - 07957 454659 or 01636 671277
