Author: Subject: 2.5 v6 duratec and type 9 box
jamesg20
posted on 24/2/04 at 09:07 PM Reply With Quote
hi all,
anyone tried mating a the v6 mondeo engine 2.5 v6 duratec with the sierra type 9?
if so whats the clutch arrangement / what parts are needed
cheers
Stu16v
posted on 24/2/04 at 10:01 PM Reply With Quote
I have read somewhere that the V6 Duratec shares the same bellhousing bolt pattern as the 4 pot Duratec. It might be worth giving Raceline a ring.
However, I wouldnt like to say how long a type 9 will last with *that* engine on the front of it.....
JJM
posted on 24/2/04 at 11:04 PM Reply With Quote
I believe all ford engines gearbox bolt pattern is the same-including the transverse ones too.
ned
posted on 25/2/04 at 09:31 AM Reply With Quote
anyone considering the duratec should remember that the jag engine is the same bottom end so could be a head swap for the jag units for an upgrade
The jag unit is 4wd, hence not sure about the gearbox, think they're mounted transverse like the mondeo?
ned.
[Edited on 25/2/04 by ned]
beware, I've got yellow skin
ady8077
posted on 25/2/04 at 06:02 PM Reply With Quote
Hi All
SSC have started using the duratec V6 in there Stylus, i think they get them from Marcos or there supplier
They also do a supercharger kit for the 3.0 litre
Adrian
Stu16v
posted on 26/2/04 at 08:11 PM Reply With Quote
Until they made the (Mazda designed) duratec.....
cosworth
posted on 26/2/04 at 08:57 PM Reply With Quote
And the 1.6 Focus SE engine
Noodle
posted on 26/2/04 at 09:51 PM Reply With Quote
ned.
The X-Type is a Mondeo (and has been pilloried here many times before.) The engine is indeed mounted like a Mondeo. As the previous generation Mondeo also provided a 4WD version, we can guess where the drivetrain layout originated from
Was that too cynical or did they indeed spend zillions re-inventing the wheel?
Neil.
Your sort make me sick
david walker
posted on 29/2/04 at 08:59 AM Reply With Quote
I know that the Jag is being knocked on here, but is that because Jaguar have rebadged the Mondeo for up market sales, or is there something wrong with the engine?
The V6 Duratec is, from my experience a strong, torquey and powerful motor in std form. They are also extremely long lasting. I have had experience of only two cars with problems - both head gaskets at high mileages. (That would equate to about 1 Duratec fault to every 300 "K Series"!).
I was looking to do something with the now readily available and relatively cheap Duratec for kit cars. Who actually has experience of them being no good - and what is that experience?
Thanks.
Dave Walker, Race Engine Services - 07957 454659 or 01636 671277
Noodle
posted on 29/2/04 at 10:05 AM Reply With Quote
Yes.
malcolmstoddart
posted on 29/2/04 at 12:32 PM Reply With Quote
now correct me if I am wrong but..
Didn't Jaguar get all of fords finest together and ask for their help on the shell and engine etc.. and each gave their own bits if information, when it came to the gearbox they for some reason went to Land rover, and when landrover came up with something more akin to mud plugging Jaguar designed its own 4wd system.Now everyone slates the x type and I am not a major fan of them but it is a first for jaguar to break from the norm and hey give them some slack I say
Metal Hippy
posted on 29/2/04 at 12:47 PM Reply With Quote
Yeah yer bastards
(I have no idea what he's on about, I'm just defending my mate Malcy the Alcy)
Cock off or cock on. You choose.
malcolmstoddart
posted on 29/2/04 at 12:50 PM Reply With Quote
Thankyou for your support Hippy, can I get off my soapbox now...
Metal Hippy
posted on 29/2/04 at 12:51 PM Reply With Quote
No.
locost_bryan
posted on 1/3/04 at 12:32 AM Reply With Quote
Is the Duratec V6 the same as the Mada/Eunos KL/KE/K8 V6 from the 626/800/MX3?
If so, the MX5 forums claim it can't run north/south due to some sort of oiling problem - designed for east/west and tilted 14 degrees to front - apparently oil won't drain properly if turned round and mounted upright.
Anyone know if this is correct?
david walker
posted on 1/3/04 at 09:47 PM Reply With Quote
Different engine. The Duratec has chain driven cams, the Mazda has belt driven cams.
The Mazda has bottom end problems when pushed. If you saw the rods you would know why!
