guff
posted on 25/2/04 at 06:05 PM |
pinto 2l carbs
hello, i havent got one yet but I am thinking 2l pinto with webers. Pretty new to carb modifications, how straight foreward is it, are there any
online guides? thanks
JJM
posted on 25/2/04 at 06:39 PM |
Basically youd need a manifold-about £60 ish new or £30 ish second hand. Then obviously a pair of Webers or Dellortos (these are just as good but
usually cheaper as they dont have Weber stamped on them!) Go for 45's over 40's as 40's dont really supply enough air if your
running a screamer-otherwise for a mild engine 40's would do. Then a linkage for about £40-use existing or new throttle cable. Or browse around
for a complete setup-these can be found for as little as £120-150. I recently sold s pair of Dellorto 40's on a crossflow manifold for £120.
45's on the other hand fetch nearly new prices-around £3-400 for a setup.
Hope that helps.
guff
posted on 25/2/04 at 07:02 PM |
certainly does cheers. just proving that i am very new to the engine tuning thing, what does dcoe actully stand for? and what does the linkage do?
cheers
JJM
posted on 25/2/04 at 08:03 PM |
DCOE is just one of many different carbs that Weber produce-its the best sidedraft carb probably.DCOE and DHLA (Dellorto) are the 2 main choices for a
pinto and are available in 40,45,48 and even 50mm!! Sidedraft means the carbs are on a horizontal plane ie the air goes in sideways, as opposed to
downdrafts where the air comes down form above, mated to a 90 degree manifold. The linkage is the part that fits on top (or below) the carbs which the
throttle cable attatches to and opens the carbs when you press the accelerator. This pic should help a little-my old RS2000 fitted with twin
45's.[img]http://locostbuilders.co.uk/upload/a88454-859422e3[1].jpg[/img]
