Author: Subject: Pinto woes
Hugh_
posted on 20/5/10 at 08:32 PM Reply With Quote
Pinto woes
I thought I was nearly there, it was running albeit not fantastically which I put down to my first "well its about right" attempt at the timing.
It is booked into Gerald Dale to setup and MoT it on Tuesday next week, and all I thought I had left to do was fit the new alternator and remove the thermostat (both done this evening), and get the timing spot on and balance the carbs.
Anyway, having done the alternator and 'stat I moved onto the timing. I turned it by hand so all the pistons were mid-stroke, removed the cam belt and was in the process of turning no.1 inlet fullly open when I noticed a gap between the cam and follower on no.1
camgap
camgap
I'm pretty sure there hasnt been any interference (I've always turned it over by hand after setting the timing and never met any resistence beyond what you'd expect from compression), there arent any marks on the piston.
I've just about had enough of it now and am very tempted to take it to Gerald on Tuesday and just say sort it. But before I do was wondering if there is anything obvious that I am missing/might be causing the valve to stick?
A rather despondent Hugh
Hugh_
posted on 20/5/10 at 08:38 PM Reply With Quote
Just realised I'm being ridiculously blonde and I havent done the valve clearences, slightly happier now
RichardK
posted on 20/5/10 at 09:10 PM Reply With Quote
Pintos are valve safe anyway unless its been heavily skimmed etc.
So don't worry mate...
Take care, you're nearly there!!
Rich
Gallery updated 11/01/2011
Hugh_
posted on 20/5/10 at 09:28 PM Reply With Quote
Cheers for the reply.
The standard 2.0l is a safe engine, but the 1.6 isnt.
Mine is a 2.1, skimmed head, Kent GP1 cam which has an extra 2.6mm of valve lift, so mine isnt safe...
RichardK
posted on 20/5/10 at 10:00 PM Reply With Quote
Aye, go careful then ! Interesting, I'm running 1.6 and thought it was safe too..
Rich
omega0684
posted on 21/5/10 at 03:28 AM Reply With Quote
rich if yours is a standard 1.6 head then it should be safe
im running a 2.1 with 50 thou of the head and inlet lift of 12mm and i have no valve to piston issues at all.
as for the original post looks like the valve clearences need sorting before you start getting involved in anything else, lol
[Edited on 21/5/10 by omega0684]
Hugh_
posted on 21/5/10 at 06:38 AM Reply With Quote
Yeah I must have been having a ridiculously stupid moment, I just completely forgot that the valve clearerances were adjustable...
mcerd1
posted on 21/5/10 at 07:38 AM Reply With Quote
alex, he means if the bet snaps
if your timming belt snapped you'd have a good chance of some valve-piston contact
and mine will be even worse I think
a std. 2.0 head & block leaves so much clearnce that it'll be still be safe - but a 1.6 head has smaller chambers etc. so its not safe
vauxhall 1.6 8v's (astra's etc) and a few others are also safe if the belt snaps...
Mark Allanson
posted on 21/5/10 at 08:04 PM Reply With Quote
If the belt snaps on a standard 1.6, you loose 3 valves, the 1.6 ecomax (a 2.0 with really narrow pistons) and the 2.0 are fine
