Davedew
posted on 16/11/10 at 09:08 PM |
CVH engine
I have filled my 1.6 cvh engine with oil, and wanted to spin it over on the starter to circulate the oil as it has been about 8 months since I drained
it down.
In total I reckon I have spun the engine over for about 5 minutes altogether. I still dont have any oil in the filter even though the sump is full to
the max mark.
Anybody have any ideas what might be wrong, or is my best bet to wait until I fire it up properly?
Dave
mookaloid
posted on 16/11/10 at 09:14 PM |
it could be a lot of things but you are doing the right thing not starting it until you have oil through out the system.
Have you had the engine apart?
martinq357
posted on 16/11/10 at 09:22 PM |
Priming problem?? Is it worth filling the filter with oil first??
Davedew
posted on 16/11/10 at 09:32 PM |
The only thing I have done is take the sump off to shorten it along with the pickup pipe. Shortened both by about 25mm. I remember putting a steel
rule on the pickup pipe and measuring to ensure it was square to the bottom of the engine block. I also measured the sump depth. I think I remember
having 3-5mm clearance under the pickup pipe.
Filter screws on sideways so any oil you put in it is likely to end up on the floor when you try to fit it.
[Edited on 16/11/10 by Davedew]
posted on 16/11/10 at 09:35 PM |
Sounds like the oil has drained down from the oil pump , you may be able prime the pump filling the oilways at the oil filter or crank it with the
filter removed. As a last resort remove the pump and fill it with vasaline . With the oil drained from the pump the vanes are not sealing
Davedew
posted on 16/11/10 at 09:46 PM |
Which of the ports to the filter should I pour the oil down, middle port which filter screws on to, or the hole in the outer area of the filter?
martinq357
posted on 16/11/10 at 10:09 PM |
You might loose some on the garage floor but if you're quick most of it will stay in.
Just like doing a normal oil change, filling the filter stops the bearings running dry during the initial startup while the filter fills.
Davedew
posted on 16/11/10 at 10:18 PM |
If I use a funnel will pouring it in at the filter port be enough, or will I need to inject it using a syringe? Wondering if gravity might pull the
oil back throught the pump. I can drain any overfill out afterwards.
cliftyhanger
posted on 16/11/10 at 10:20 PM |
and worth taking the plugs out so the engine will spin up easier.
Now, happy to be wrong as working from memory and no diagrams within easy reach, but the oil would be supplied from the pump to the outside of the
filter? Worth squirting some oil down there, leave for a bit and then spin it up again.
EDIT. I would just use a squirty oil can. It may be possible to access the oil relief valve and squirt oil in there?? I know you can with some engines
(like my old triumph lumps)
[Edited on 16/11/10 by cliftyhanger]
Davedew
posted on 16/11/10 at 10:24 PM |
Plugs are out as you suggest. Middle port and pressure switch a straight line. I put some oil in the middle port and it came out the pressure switch.
Might try filling filter and put it on over night to see if it runs back to the pump.
Davedew
posted on 16/11/10 at 10:47 PM |
You can get the oil relief valve out no problem. You reckon it's worth a go squirting some oil in there?
procomp
posted on 16/11/10 at 11:46 PM |
Hi
Yep you need to get oil into the pump for it to suck any oil through. Oil pressure release valve will do to prime the pump and fill oil filter as
suggested.
Cheers Matt
skodaman
posted on 17/11/10 at 12:12 AM |
Might be worth taking the sump off to check if your calculations were right. It's possible you could have tightened up the sump blocking the
end of the pickup.
Skodaman
will121
posted on 17/11/10 at 07:23 AM |
i used a rebuilt 1600cvh and turned it over for ages with the plugs out to try and get oil pressure to show its self, but it just wouldnt, finally
ended up fingers crossed and just started it, oil pressure came up straight away so i was happy but could have gone the other way.
FASTdan
posted on 17/11/10 at 07:32 AM |
My 1600CVH can take 2-3mins of cranking when its been stood before it'll generate oil pressure.
The relief valve is a direct line to the pump so if you can get access this is probably the best place to prime it.
I once had a sticking relief valve on the same engine so if you still struggle it might be worth looking at. Remove the spring, insert a screwdriver
and give the back of the valve a tap, if it moves its been stuck.
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
r1_pete
posted on 17/11/10 at 07:56 AM |
Reverse fill the galeries and oil pump via the oil pressure take off point, use a squirt type oil can and whatever you need to seal between the sopout
and block.....
Davedew
posted on 17/11/10 at 10:04 AM |
I took the filter off and jammed a funnel into the center port of the oil filter last night. Left it full with oil to see if gravity would work. Oil
has gone this morning, and it isn't all over the floor or side of the engine. Hopefully ran back through pump into sump.
I'll squirt some oil in through the pressure relief valve tonight and give it another go.
Don't really want to drop sump as I'll have to split engine & gearbox again.
Thanks for all the advice, i'll let you know how I get on.
Jenko
posted on 17/11/10 at 01:03 PM |
Also you need to check the pickup pipe connection to the block....this has a small gasket that needs to be in good condition any air around here and
it wont work. The design of the cvh oil pump should mean if you have the pickup submerged in oil it 'Should' pick up the oil..... Assume
oil pump is good nick and relief valve is not sticking open...
MY BLOG - http://westfieldv8.blogspot.co.uk/
Davedew
posted on 17/11/10 at 01:19 PM |
Gasket from pickup pipe to oil pump was a new one when I put it back together, and bolts torgued to correct setting. I'll give it another go
tonight after injecting oil through the relief valve.
When I got the engine it was full of brand new oil. The car it came from had just been serviced before it got broken. Filter was full with oil. I hope
it is just a priming issue. I think the 1600 cvh engines are a bit prone to it.
Davedew
posted on 18/11/10 at 08:38 AM |
We'll I have pumped oil into the oil pressure relief valve, through oil filter & cranked with filter off. All the things suggested above,
and I still get no show of oil when I crank it over.
All the time i'm pumping oil in, the level in the sump is going up, I'm assuming the only way to the sump is back through the oil pump?
I'm thinking to just try and start it and see what happens.
Any thoughts?
Dave
