<<  1    2  >>
Author: Subject: Have you painted the inside of your garage?
Andy W
posted on 22/10/13 at 08:02 PM Reply With Quote
I'm shortly about to move house, and wondering should I paint the inside walls on the garage white before I fill it.
I currently have a brick garage and never bothered when I moved in, but soon got to the stage were it would be an almost impossible task.
I'm just wondering if I should paint the new one before I get all my shelves / gear in there.
I'm thinking I should, but the only thing putting me off is that when it gets dirty in the future, it would look worse than if I hadn't bothered in the first place.
What have people done? if you have painted the walls have you regreted it?
balidey
posted on 22/10/13 at 08:08 PM Reply With Quote
Yes, do it. Keeps dust down, brightens it up no end, helps reflect light from overheard fluorescent tubes.
Dutch bears have terrible skin due to their clogged paws
jossey
posted on 22/10/13 at 08:09 PM Reply With Quote
I bought 100 x 1 meters of silver foil insulation (£24) and used spray adhesive straight to the walls white side facing in.
I did paint the walls before hand but decided I like warm than a pretty wall.
If you do paint the walls pva them first should stop it pealing as much.
Dj
David Johnson
T66
posted on 22/10/13 at 08:28 PM Reply With Quote
Mine got lashed with white paint before it all went in - most of the walls are covered now but it does look better than brick.
posted on 22/10/13 at 08:42 PM Reply With Quote
Mine was already painted white (integral garage boarded out and skimmed) and it does improve the environment considerably. I'd like to paint the bare concrete floor with light grey floor paint as well to further brighten it up, but that would mean emptying it, which is very unlikely to happen!
posted on 22/10/13 at 08:45 PM Reply With Quote
Do it.
I was going to before I moved all my stuff in, but never got round to it. I really regret it now.
As Balidey said, it keeps dust down and really brightens things!
It's Evolution Baby!
SALAD
posted on 22/10/13 at 08:46 PM Reply With Quote
I painted the floor and walls. Bought the proper floor paint then got a load of free white paint (probably with wee in it) from the tip. Still looks bright and nice after years....do it.
Edit: Love the auto correct for piss!
[Edited on 22/10/13 by SALAD]
mark chandler
posted on 22/10/13 at 08:52 PM Reply With Quote
Makes a huge difference, need to finish mine off still, plasterboard the exposed joists and paint the ceiling. more light the better.
Andy W
posted on 22/10/13 at 09:03 PM Reply With Quote
looks like I'm painting the walls then, fortunately I can do the work before I need to move.
I think it's gonna take longer to move everything out of the garage than the house.
mortsi
posted on 22/10/13 at 09:38 PM Reply With Quote
im a plasterer if i had a decent size garage it would be all plasterborded out walls and ceilings plastered then painted but unfortunatley i only have a small pre-fab just big enough for the car fits like a glove
trextr7monkey
posted on 22/10/13 at 09:39 PM Reply With Quote
I went with pale yellow which looks warmer than white and apollo blue floor, painted in sections looks very cheerful. Used Lelyland trade paint and pleased with result
Atb
Mike
yellowcab
posted on 22/10/13 at 09:42 PM Reply With Quote
Most rewarding job in the world for any clean & neat freak... not to mention the dust aspect as mentioned above.
Keep the colours light, reflects lots of light
Cut into strips, to place in between the concrete ribs of the garage
Done... nice and cosy - already reduced / eliminated echo
finally finished... feels like it's took forever
So after building some work benches, we decided to clear out because it'd be rude not to have a little photoshoot in the studio lol
MikeR
posted on 22/10/13 at 09:46 PM Reply With Quote
I did mine and used masonery paint cause its, err, masonery.
made a huge difference and id recommend it.
Chrisjohns
posted on 23/10/13 at 06:30 AM Reply With Quote
Wish I'd done the walls, but have done the floor a number of times. Dulux trade centre have probably the best value floor paint. Need to give it at least 12 hours between coats.
steve m
posted on 23/10/13 at 07:22 AM Reply With Quote
Ive painted the garage floor grey,
Well I actually did not paint the floor, I poured a load of paint on the floor and let it flow/run away and then used a squeegee on a broom handle to pull the paint around
sooo much easier than rollers or paint brush, it also self levels and dents
40inches
posted on 23/10/13 at 07:41 AM Reply With Quote
Paint it at a minimum. I put a layer of bubble foil, battens and plaster board before painting, made it much warmer in winter.
And a lot brighter.
mcerd1
posted on 23/10/13 at 07:46 AM Reply With Quote
proper light grey floor paint for me too - reflects the light and makes a huge difference to the amount of dust
for the walls I just used 2 coats of the cheapest white emulsion I could find, but mixed the first coat ~10:1 with PVA
[Edited on 23/10/2013 by mcerd1]
thefreak
posted on 23/10/13 at 08:55 AM Reply With Quote
I moved into a new house with double garage 3 years ago and the first job before the garage got filled was to paint the floor and walls.
Trade floor paint and masonry white wall paint made a huge difference.
My one regret was not levelling the floor before painting it. With all new builds the builders don't care much about the state of the floor in the garages and usually leave it full or ridges. Now trying to move the heavy trolley jack around is difficult, and the paint is starting to chip up.
I think the plan for next summer is to get everything out and get it levelled. It's a lot more difficult when it's full than when it's empty.
DIY Si
posted on 23/10/13 at 02:34 PM Reply With Quote
Not painting a garage or workshop is a daft idea to me. What ever the walls and ceiling are, painting them a nice light colour makes such a difference. When mine went from bare wood to white trade paint it made such a huge difference and it's really bright in there.
Sun Tzu, The Art of War
slingshot2000
posted on 23/10/13 at 03:01 PM Reply With Quote
Originally posted by DIY Si
It's really bright in there.
Wouldn't happen to have anything to do with the number of fluorescent lights you have in there, would it ?
CNHSS1
posted on 23/10/13 at 03:11 PM Reply With Quote
Originally posted by yellowcab
walls colour matched to tyre treads, very neat
mcerd1
posted on 23/10/13 at 03:14 PM Reply With Quote
but think how many lights he'd need if the walls/floor/ceiling wasn't painted
Cadburys Man
posted on 23/10/13 at 03:36 PM Reply With Quote
I need to paint mine and plasterboard the ceiling etc but 3 years later I've still not sorted it :-/
Mainly due to lack of money cos i can't stop buying new toys lol.
Daz.
Stuart Taylor ZX9-R Locosaki
T66
posted on 23/10/13 at 04:49 PM Reply With Quote
I haven't painted my floor, preferring off cuts of carpet around the car, my old knick knacky knees prefer padding on a deep pile....
Painted floors do look good, but I'm often grinding/cutting so there's crap everywhere anyway.
steve m
posted on 23/10/13 at 05:09 PM Reply With Quote
I think we have all been there with bits of old carpet etc
But as winter approaches, I like to think that going out into a coldish garage is as pleasant as possible
and having good lighting and a clean environment, really does help
I have had a monster throw out of crap I will never need, and its amazing how much space that can generate
My pathetic small garage on the side of my house (no way of expanding it) is just adequate for my 7 to live/work on
But Oh how I wish to have a garage like some off the pics above !! you bastards
<<  1    2  >>
