minibull
posted on 13/7/14 at 05:32 AM |
floor mounted dip switch
Hi haven't posted before but I'm in the process of building a replica of a 1963 Falcon mk111 Competition sports racer based on a custom
built Autotune Gemini frame and body (the Gemini being based on the Falcon).It will be as close to the original as possible with Ford pre x flow
engine though with square tube and 5 link rear rather than round tube and A frame, + other mods to get through IVA. I would like to use a floor
mounted dip switch as correct to period but can't find in IVA manual if permitted or not.
Mick
owelly
posted on 13/7/14 at 05:50 AM |
No help with the IVA/floor switch thing, but I thought the Autotune Gemini was based on the Elva?
http://www.ppcmag.co.uk
minibull
posted on 13/7/14 at 06:04 AM |
Elva mk1's used a Falcon Competition body (though the first of them had custom alloy bodies and the first glassfibre bodied one used a Microplas
body).
Mick
adithorp
posted on 13/7/14 at 07:53 AM |
No reason not to use a floor dip switch in IVA manual AFAIK.
http://jpsc.org.uk/forum/
loggyboy
posted on 13/7/14 at 09:01 AM |
Nothing to stop you adding it retrospectively.
Mistral Motorsport
Canada EH!
posted on 13/7/14 at 04:37 PM |
Mk 1 Sprite floor switch is quite small.
minibull
posted on 14/7/14 at 02:53 AM |
Thanks for replies.I'll fit one and see what the examiner makes of it. The advice for retrospective fitting is sound but I would prefer it to be
done during initial build as alterations are needed to footwell and that becomes more difficult once its already completed, not to mention all the
other changes that wil be required post IVA.
Mick
