Author: Subject: carb balancer
alan87
posted on 7/1/15 at 10:11 AM Reply With Quote
carb balancer
Ive picked up a new project and need to get it running right. Its on twin su-hs8 carbs, anyone got a balancing tool they know longer want?
theduck
posted on 7/1/15 at 10:58 AM Reply With Quote
Can't help with the balancer but is the aristocat the new project? If so is it the one that was on eBay last week?
19sac65
posted on 7/1/15 at 12:38 PM Reply With Quote
You can get them off ebay for less than £40
A good investment if you run multi carbs
I got my 4x bike carbs set 99% by using some mig wire as a feeler underneath the butterflys
Set them both to just touch ( balanced) then start and adjust equaly to set idle
alan87
posted on 7/1/15 at 02:36 PM Reply With Quote
Yeah if no one has anything ill pick up a Gunson one from the bay.
Theduck - no i got this back in july. Bit of a barn find, good spec but untidy non runner for a few years so needs tlc. 4.2 but with a manual box so should be good.
theduck
posted on 7/1/15 at 03:16 PM Reply With Quote
Sounds good! Good luck with the build
19sac65
posted on 7/1/15 at 03:41 PM Reply With Quote
These work well with SU's
290682796527
Ebay item
Slimy38
posted on 7/1/15 at 05:07 PM Reply With Quote
I've always used a variation of this idea on my carbs;
http://www.powerchutes.com/manometer.asp
