Author: Subject: Megasquirt rolling road setup?
40inches
posted on 24/2/15 at 09:45 AM Reply With Quote
The intention was to take it to Baileys Performance, but there appears to be a Megasquirt specialist at Donnington. A hell of a lot nearer.
Anyone used them? http://www.ms2tuning.com/
[Edited on 24-2-15 by 40inches]
wombat
posted on 24/2/15 at 12:17 PM Reply With Quote
Do you realise that's lincs not the circuit?
40inches
posted on 24/2/15 at 02:04 PM Reply With Quote
I do now! 70 miles away from home as against 91 miles to Baileys Closer, but about the same 2hr travelling time.
40inches
posted on 24/2/15 at 02:13 PM Reply With Quote
The web site says that they will come to you!!! Wonder what that would cost?
BaileyPerformance
posted on 24/2/15 at 02:22 PM Reply With Quote
They are a mobile mappers i think, no rolling road.
www.facebook.com/baileyperformance
40inches
posted on 24/2/15 at 02:33 PM Reply With Quote
Looks like you are still favourite then
BaileyPerformance
posted on 24/2/15 at 02:45 PM Reply With Quote
Good , thanks, to be fair its is possible to map a car on the road (fuelling only) i used to do it that way before i bought the dyno, but it is hard to optimize the ignition.
I would be interested in knowing what they would have charged, i think i'm too cheap and plan to increase what i charge soon.
r1_pete
posted on 24/2/15 at 02:52 PM Reply With Quote
No don't I need to get the Jag down to you too, and just can't find the garage time with the freezing weather and work to finish the install...
EFI Trial Fit 2
EFI Trial Fit 2
[Edited on 24/2/15 by r1_pete]
BaileyPerformance
posted on 24/2/15 at 02:59 PM Reply With Quote
EFI Trial Fit 2
EFI Trial Fit 2
I would be very interested in how your ITB setup works, think i have said before we tune afew old Jags, did a 3.8 and a v12 recently.
The V12 on six weber 45s , microsquirt (ignition only) and MSD made 381BHP and 416lb/ft!!! My engine builder and i nearly fell over.
40inches
posted on 24/2/15 at 03:12 PM Reply With Quote
Noooooo! Well, not until you have done mine
Jenko
posted on 24/2/15 at 05:16 PM Reply With Quote
I wrote an article a few years (for the westfield mag) back with Troy from Northampton Motorsport about road tuning Vs Rolling road. It was basically a challenge, I spent a year or so fine tuning ignition and fuel maps, and reckoned it was pretty good. Troy reckoned he could better it....Guess what...He was right :-)
Anyone wants a copy, PM me your email.
[Edited on 24/2/15 by Jenko]
MY BLOG - http://westfieldv8.blogspot.co.uk/
ashg
posted on 25/2/15 at 03:43 AM Reply With Quote
you can do ignition timing and fueling on the road but you need a good set of det cans and mslog viewer. it will be a good map but wont get that last few horses out.
what you cant do on the open road is accurately and repeatably measure if the change you made to ignition or fuel added or reduced power once you get to a 90-95% decent map.
with det cans you are basically just tuning trying to keep the engine away from detonation and using feel in the seat for power measurement.
A good example. Your peak torque at 3500rpm may be made at 25btdc but you may not experience detonation until 31btdc. on a rr you can find that by taking measurements which show at what ignition advance torque peaks at and falls off at. With det cans on the road you basically take it up to the point of detonation then wind it back a couple of deg to be safe, the negative to doing that is that the peak power is down at 25btdc but you may end up at 27-28 which is just of peak!
more and more these days through good engine design peak performance is achieved well away from the detonation zone, so if you want every little bit of performance out of that engine your gonna need a RR, on the other side of the coin if your happy with 90-95% with great drive-ability then road tuning can be successful
i would say a good respected on road tuner dont pay more than £200ish. for a well respected tuner with a RR expect to pay £300+
a good tuner not only knows how to punch numbers into a pc until they get maximum oooompth they also understand mechanics and the physics of internal combustion and engine design. The relationship between gas flow, peak cylinder pressure, rod/piston ratio, inlet/exhaust design, flame front, cylinder gas scavenge, mechanical timing, fuel delivery/atomization, and stoic ratios are just a few of the concepts you need to get working together in your head before you can be a really good tuner. After learning that foundation, years of experience comes into play.
properly understanding all of that including the math needs a good bit of intelligence. chances are if you meet a great tuner that fully understands all of that and can produce great results means one of two things. They either already work for a professional race team or they undervalue themselves and are under charging as they could be earning a lot more money using their brain for a higher paying career.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
BaileyPerformance
posted on 25/2/15 at 10:29 AM Reply With Quote
I knew i was cheap at £250/day, which is about half what i used to earn as an engineer for an automation company in the oil and gas industry.
I fully agree with your point regarding an understanding of what is actually going on within an engine, its not just a case of tweaking afew numbers on the laptop, we have seen some stunning examples of poor tuning over the years, recently an Omex ECU mapped by a well known tuner with 31deg of timing at idle on a vauxhall 16v, i can only assume was an attempt to bring the idle up, anyone with basic knowledge of an engine knows this is far too much timing.
I dont really agree with the maximum advance to make it knock approach, an engine like a NA zetec will take over 36deg without knocking but will make maximum power 28-30. This i why i think you cant map the ignition curve on the road, but you can just about map the fuelling given enough time.
Oddified
posted on 25/2/15 at 12:22 PM Reply With Quote
Fueling isn't that hard to do on the road, wide band/data logging etc and time.
Ignition isn't as easy, but on the other hand it's not hard to find or make an ignition map that is 90% in the ball park straight off for most engines with some common sense. Engine feel and sound, back side dyno and det cans for fine tuning. The last 5 or 10% isn't really feasible but then while the last fraction can be found on the rolling it's also effected by the tank of fuel and atmospheric conditions on the day so the last 'bit' isn't a constant any way. On the rolling road an engine might be best with say 26.2 btdc/4250rpm at wot, 6 months later with different weather and fuel...
After saying all that, unless it's part of the fun to someone learning something new and a personal challenge, the majority would be better off using a good rolling road. Note the word 'good', plenty have no idea.
Ian
ashg
posted on 25/2/15 at 01:11 PM Reply With Quote
the way i like to say it is........ There are many rolling roads, not all of them good.
jeffw
posted on 25/2/15 at 02:41 PM Reply With Quote
there are many operators of rolling roads, some are better than others !
baz-R
posted on 10/3/15 at 10:04 PM Reply With Quote
my own MS road tune was 159bhp (all my own settings) an hour rolling road time with a pro gave me 165.1bhp we could add 9 degrees to the full advance with no pinking or det just power loss. the guy did it just to prove his point that in reality max power is not made near to det point.
blakep82
posted on 10/3/15 at 10:17 PM Reply With Quote
And mine! I'm getting there, wiring at the moment, still
________________________
BaileyPerformance
posted on 11/3/15 at 08:46 AM Reply With Quote
I couldn't agree more. This is why the "listen for det, then retard abit" is the wrong way to do it.
www.baileyperformance.co.uk
BaileyPerformance
posted on 11/3/15 at 09:04 AM Reply With Quote
Don't panic! will do yours for what we agreed :-)
Oddified
posted on 11/3/15 at 09:54 AM Reply With Quote
True but it all depends on the engine (age/design has a big impact) and how much it's being pushed. Throw some boost into the equation, less than ideal intake temps and the best ignition timing for power isn't that far below det. To much boost, to much compression, high air temps and det is the limiting factor on ignition timing. The large gap between optimum timing and det is normally only on modern engines, normally aspirated and unstressed (not being pushed to the limit).
Ian
