Author: Subject: Wheel bearing seals
Phil_1471
posted on 19/7/16 at 05:29 AM Reply With Quote
Wheel bearing seals
Morning all.
My wheel bearing seals on the Riot arnt as good as they used to be... Does anybody know the part numbers of them front and back?
Rear hubs are xr2i fronts I think?
Fronts are Capri??
It's the original riot if that makes a difference?
Help please
Phil
You can live in a car but can't rally a house
posted on 19/7/16 at 08:23 AM Reply With Quote
I'd start at a Ford dealer and ask there - my local one was very helpful and asked me to take my MK Indy in when road legal.
Failing that a good motor factor should be able to help with parts to suit.
The other place to try may be Burton Power - pretty knowledgeable on Ford parts.
[Edited on 19/7/16 by nick205]
myke pocock
posted on 19/7/16 at 10:57 AM Reply With Quote
If you look at the face of the seal you should see a series of numbers, should be three of them I think. Just quote those to a seal supplier and they should be able to supply. Probably find that they are cheaper this way as well rather than Burton or Ford.
Phil_1471
posted on 19/7/16 at 05:16 PM Reply With Quote
Which one are we saying?
myke pocock
posted on 19/7/16 at 06:16 PM Reply With Quote
Ah, looks like as it is an OE seal they dont mark it up the same. The numbers I use refer to the shaft size, OD and the thickness of the seal, eg 38-56-12. If you want to measure things and let the seal supplier now they could probably find one to suite.
ian locostzx9rc2
posted on 19/7/16 at 07:45 PM Reply With Quote
The ford part no is the one with BA at the end of it
