Author: Subject: Thermostat Solutions anyone?
VinceGledhill
posted on 4/1/05 at 09:35 AM Reply With Quote
Hi People.
I've got a Sierra Pinto engine in my locost and am in need of a thermostat solution for the fan.
I don't want to buy one of those which fits into the hose because I think it's an expensive option and is a nightmare to fit and get sealed properly (been there done that)
Can anyone recommend one that is threaded? or an alternative solution for the pinto. I've got a MK 5 cortina radiator fitted and there's no where for one to fit on that.
Regards
Vince Gledhill
Time Served Auto Electrician
Lucas Leeds 1979-1983
vintagebuilder
posted on 4/1/05 at 09:47 AM Reply With Quote
Vince,
In the Which Kit build series on the MK Indy it showed a thermostatic sensor which fitted between the radiator fins. I've never seen one of these in any of the catalogues but presumably they do exist.
Regards
mookaloid
posted on 4/1/05 at 11:29 AM Reply With Quote
How about this?
Not exactly Low cost but look the business!
http://www.demon-tweeks.org.uk/catalogue/product_detail.asp?CLS=ROAD&TLGRP=R006&CODE=GLOEFC&PGRP=RP065&GRP=RP065&PCODE=GLOEFC25 />
HTH
Mark
mookaloid
posted on 4/1/05 at 11:31 AM Reply With Quote
VinceGledhill
posted on 4/1/05 at 12:37 PM Reply With Quote
Thanks guys. I could do with just the middle bit and can fabricate my own brackets etc. Like you say Mookaloid, not exactly locost.
I just wish I knew which car to get a threaded one from?
Ideas anyone. Thermal switch that is threaded? Goes short circuit when the engine temp gets to say 95 or so?
Regards
Vince Gledhill
timf
posted on 4/1/05 at 12:39 PM Reply With Quote
polo fan switch from a polo rad
VinceGledhill
posted on 4/1/05 at 12:41 PM Reply With Quote
Cheers M8. Is that threaded?
Regards
Vince Gledhill
Mix
Ditto for Micra fan switch
Mick
Mix
posted on 4/1/05 at 12:45 PM Reply With Quote
They are both threaded but I don't know the thread off the top of my head, however the Micra is 16mm across flats, Polo is 29mm across flats.
Mick
stephen_gusterson
posted on 4/1/05 at 01:01 PM Reply With Quote
mk1 or mk2 fiesta
screws into top hose / thermostat housing
atb
steve
VinceGledhill
posted on 4/1/05 at 01:15 PM Reply With Quote
Any chance of re-posting that picture Steve? It's not come out on the forum. Or it doesn't appear so to me.
Regards
Vince Gledhill
907
posted on 4/1/05 at 04:57 PM Reply With Quote
Hi Vince
I know you didn't want an "in the hose job" but it is threaded.
M14 x 1.5 Fits a Volvo £9.38 +vat
On at 89 deg - off at 86 deg
Any help ?
stephen_gusterson
posted on 4/1/05 at 05:32 PM Reply With Quote
if you mean me, I didnt post a pic
atb
steve
stevebubs
posted on 4/1/05 at 06:48 PM Reply With Quote
The Escort had a threaded fan switch (As did fiesta). Just pop into your local motorfactors and ask for one.
Alternatively, go to somewhere like www.burtonpower.com..under Instrument Accessories you'll find a few Fan Temperature switches (and pics)
HTH
theconrodkid
posted on 4/1/05 at 06:57 PM Reply With Quote
i used a peice of stainless tube,drilled a hole and araldited a metro switch in,still working after 3 years
who cares who wins
pass the pork pies
NS Dev
posted on 5/1/05 at 02:13 PM Reply With Quote
yep, or just mig a piece of stainless to the side of the tube with an appropriate thread in it.
Rob Lane
posted on 5/1/05 at 03:35 PM Reply With Quote
Found this in my 'useful info' email folder :-
"Look at the older around (1990 vintage) Saab 900 upper rad hose they have a
very nice aluminum segment that is inline with the rad hose. It has a very
nice screw in electric thermostat switch. It is a very clean installation
that works very well. You can mount it in the upper or lower rad hose and the
part can be had cheep at many salvage yards. Different temp thermostats can
be bought to suit any need."
