Author: Subject: What’s this called?
snapper
posted on 20/5/18 at 08:48 AM Reply With Quote
What’s this called?
What’s the cable marked 17 called?
I have several sets of carburettors and the Mikuni carbs have a much longer thread on the end which is the one broken on my set
Need another one
[img]https://www.flickr.com/gp/152569273@N05/HfasU7[/img]
[Edited on 20/5/18 by snapper]
I eat to survive
I drink to forget
Ugg10
posted on 20/5/18 at 09:03 AM Reply With Quote
Picture not working, think you need to use the bbcode Flickr link to pit pictures in here.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
snapper
posted on 20/5/18 at 10:21 AM Reply With Quote
I have now put the image in my archive
[img] Mikuni
Mikuni
[/img]
I eat to survive
I drink to forget
Slater
posted on 20/5/18 at 02:32 PM Reply With Quote
Hard to see item 17 on the blurred image, but if its the upside question mark shaped thing?.....I believe it's the idle adjustment cable, you twist the knob on the end and somehow it adjusts the idle speed.
russbost
posted on 20/5/18 at 04:26 PM Reply With Quote
As said, impossible to read the image, but if it's what's described above you can just replace with an ordinary idle screw, just need something of correct thread. On bikes you have the flexy adjuster as impossible to acces carbs without stripping down on modern bikes due to fairings etc.
gremlin1234
posted on 20/5/18 at 04:45 PM Reply With Quote
following the answers above, I find it is indeed 'idle adjuster' TM33/38
and part 18 is a clip to hold it in place
http://www.mikuni.com/pdf/tm33.pdf
from
http://www.mikunioz.com/tuning-tips-and-manual-downloads/
