zzr1100rick
posted on 27/12/05 at 04:14 PM |
zzr1100 standard sump
Hi any one using a zzr1100 with a standard sump ? if so have you had to baffle it or just relied on the fact its a fairly deep sump
as i think putting a shallow sump on is asking for oil surge and problems
cheers Rick
zzrpowerd-locost
posted on 27/12/05 at 09:49 PM |
Have a word with Chris Gamlin on here, does stuff with them. Shortening, baffling ect
You not having any luck with finding a GPZ sump then??
Easy when you know where to look
Sump, pickup pipe Ect
http://cgi.ebay.co.uk/Kawasaki-GPZ-900-R-ZX900A-Motordeckel-Olwanne_W0QQitemZ8010310234QQcategoryZ49821QQrdZ1QQcmdZViewItem
Oil filter Cap
http://cgi.ebay.co.uk/Kawasaki-GPZ-900-R-ZX900A-Olfilterdeckel_W0QQitemZ8010310324QQcategoryZ49821QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Ah! German Ebay
[Edited on 27-12-05 by zzrpowerd-locost]
zzr1100rick
posted on 27/12/05 at 10:20 PM |
want to leave the original sump on so as to try and stop loss of oil pressure due to oil surge just wondered if any one else was using the
original sump still
Guinness
posted on 28/12/05 at 08:59 AM |
I don't know about the Luego chassis / bodywork, but I used the GPZ900 sump on my MK Indy.
The MK has (IIRC) 1" taller body work and a massive bonnet bulge. I just managed to get the carbs and air filter in under the bonnet. Any
higher and I would have had to cut a hole in the bonnet. This left the standard sump sitting 75mm below the chassis rails. No good for speed humps
on a car with 125mm ground clearance.
The GPZ fitted straight on (thanks for the tip Rorty) and touch wood I haven't had any problems with the oil yet. It's also only about
20mm below the chassis rails now, so I can get out of my own street.
I'm not sure you would get oil surge problems as it picks up from the round well in the middle of the sump, via a strainer that sits in the
well. It's not like a car sump which is flat bottomed and has a pipe in the middle.
Hope that helps.
Mike
