Northy
posted on 22/2/03 at 02:41 PM |
Baffle the sump?
How do I baffle my sump properly? Some pictures would be nice!
Thanks alot
Graham
Mark Allanson
posted on 22/2/03 at 05:34 PM |
Have a look in my pickies on how I shortened the sump, there is no shot of the baffle, but I cut a piece of 18g steel the same shape as the deeper
part of the sump and cut a hole in it for the pick up gauze to fit through, I welded this 1" from the bottom so when cornering, the oil can only bank
up in the side to a max height of 1".
I dont know if this is right, but I cannot see how it wont work OK.
Northy
posted on 22/2/03 at 06:37 PM |
Thanks,
I was thinking of baffling it vertically aswell, is that a good idea?
Graham
Mark Allanson
posted on 22/2/03 at 06:54 PM |
I am not sure if you can 'overbaffle a sump', but with my sump mod, I will have about 10 pints capacity(!) so I was unsure if I would need any
baffling at all, but did it just in case.
Lads with completed car on the road might be able to answer this one better
Northy
posted on 22/2/03 at 07:05 PM |
My sump (for a Vx) engine will only be 8cm deep. I was thinking of extending it forward an flat like yours, but aslo put a box on the side aswell.
Does it matter if there is 'too' much oil capacity, I rather that than too little!
Th windage tray protrudes into the sump a little, so there isn't much room for baffling!
Any ideas?
Graham
Northy
posted on 23/2/03 at 12:25 PM |
Can anyone help please?
Graham
Mark Allanson
posted on 23/2/03 at 11:00 PM |
I am sure that too much oil capacity is nor a problem, it will give the oil time to cool and to defoam as it settles in the sump.
Northy
posted on 24/2/03 at 07:41 AM |
Thanks Mark,
Has nobody else on here done this?
Graham
eddymcclements
posted on 25/2/03 at 11:23 AM |
Yes. See the following:-
http://www.whirl.demon.co.uk/locost/cutsump.jpg
http://www.whirl.demon.co.uk/locost/shortsump.jpg
http://www.whirl.demon.co.uk/locost/sumpbox.jpg
http://www.whirl.demon.co.uk/locost/baffled.jpg
Not the only way to tackle the problem, but I wanted a box around the pickup pipe with a trapdoor to prevent surge under acceleration and a horizontal
baffle to prevent surge under cornering.
The capacity remains the same as standard. Note that this engine already has a windage tray under the crank.
You should also take a look at:-
http://dspace.dial.pipex.com/ian.crocker/sumps/baffle.html
and scroll down the page.
HTH,
Eddy
kingr
posted on 25/2/03 at 11:31 AM |
One thing that having more oil than normal would cause would be slower warm up, not necesarily a problem, just something to think about.
Kingr
thetankwad
posted on 27/2/03 at 11:15 AM |
I may be on the wrong tree with a barking spree, but have you thought about a dry sump conversion? Dont know too much about these, but they may help
your situation...
