Various measurements please
OK, I'm after two sizes and two measurements if possible, so, here's what I'm after :
Socket size required to undo X/flow big end bolts
Socket size required to undo x/flow main bearing caps
Diameter of spigot bearing hole on any ford 4 pot, as I believe they're all the same
Depth of hole for spigot bearing, preferably x/flow, but I'd guess that they're all pretty similar since they take the same bearing
Once I know these, I should be able to take my crank out and get someone to drill a dirty great hole in the end of it.
Regards,
Kingr
