zetec
posted on 28/2/03 at 01:03 PM |
Air Box
I was looking to fit normal K+N filters with a hole for them to stick out of the bonnet, but now fancy trying to fit a air box and remote filter.
Has anyone else done this with either twin carbs or throttle bodies? I have seen some on the market but don't fancy paying £350+ for a carbon fibre
one. Looks like the choice is source one off a bike or knock one up in ali (or get PTM to make one for me?).
kingr
posted on 28/2/03 at 01:45 PM |
What are your reasons for doing this? If you want possibly less disturbed air going to the carbs, then this may help. If you want to avoid cutting a
hole in the side of your bonnet, then it's not going to help, because you're going to need trumpets in their anyway, there's a minimum distance
that you can have a surface from the trumpets, and you can get K+Ns that are as narrow as feasably possible anyway, so your airbox would stick out
just as much as filters would.
Kingr
zetec
posted on 28/2/03 at 02:11 PM |
I have the required space from the trumpet to the inside of the bonnet. Yes one reason is that I don't want a hole in the bonnet, the other is to get
a cool air feed. The other problem with the K+N is that they have a solid plate opposite the throttle body throat that will reflect the induction
pulse back. A curved air box would reduce this.
kingr
posted on 28/2/03 at 03:31 PM |
I know I'm still not answering your question directly, but could you not leave the bonnet intacked (or 4 subtle holes if you particulary want), and
use ducting. If you don't like the K+N solid plate, how about a curved filter?
Kingr
