Author: Subject: capri 2.0l
Jamesfear
posted on 4/5/03 at 06:21 PM Reply With Quote
capri 2.0l
I have the option on two capri's one is a 2l and the other is a 1.6l. Are the engines the same as the ones in the escort and sierra?
whice one would you go for if you had the option of the two?
I am going to be using the 7 +4 chassis will the 2l fit in to this with out to many mods?
thanks
james
spalding clubgti host
Mark Allanson
posted on 5/5/03 at 11:08 AM Reply With Quote
I would go for the 2.0, you will get a 3.44:1 diff instead of the 3.75:1 which will give more relaxed cruising, and with the 2.0 engine, will not affect accelereation too much.
I have a 3.75:1 axle from a capri and a sierra 2.0i engine and box, all going in a standard book chassis, in hind sight, I wish I had gone for the 2" wider chassis just to make things a bit easier in the engine bay and giving me more choice when buying seats. I have done a pdf file about how to fit a capri axle into a book chassis if you want it.
Jamesfear
posted on 5/5/03 at 06:39 PM Reply With Quote
thanks m8
That pdf would be good thanks.
Thanks for posting there does not seem to be a lot of people that know anything about the Capri and a locost on here.
